My SRT6 fixed itself by being driven! Hopefully...
Old Nov 3, 2012 | 12:15 PM
steverwrx's Avatar
Default My SRT6 fixed itself by being driven! Hopefully...
I have not posted on here for a long while but I figured I would share my little story. In the past year and a half I bought a new house with a longer commute and a new daily driver car in a '92 Mazda Miata. With the new situation, the "Chuck" the SRT6 does not get driven as much. I have put 21K miles on it in the five years i have owned it but only 1500 in the last year. A couple weeks ago my wife and I head off to a car show and decided to take Chuck. Filled up with gas and hit the freeway. I got to about 35/40 on the on ramp, then floored it and it launches as normal for about a second or two then nothing! We got up to about 70 then no throttle response at all. No check engine light. So we ended up coasting almost to the next offramp. It would just idle and not rev at all even in park. Turned off the car and turned back on and it seemed fine but I did not floor it. Drove to a safe spot to park and I plugged in my OBD2 reader. Got a P0123 Throttle position high voltage code. Wife was not happy about the situation so we drove home and took her car to the car show.
Later that day I searched P0123 code on here and found some information and possible solutions in wiring connectors, throttle pedal and/or TPS on the throttle body. Each solution being more expensive than the last so I was not too happy. So yesterday I had an errand to run and decided to take Chuck. I cleared the P0123 code and performed the throttle reset procedure. Drove a few miles to get everything up to temps and floored it. Awe crap! Same problem with no throttle response. No CEL but got the P0123 pending code again. Turned off ignition and restarted and the throttle was back. Headed off down the freeway for about 20 miles. Never flooring it but the reader was still coming back as P0123. About 10 miles into the return trip and the reader shows no code! Run it again and no code. I am still about 10 miles from home so i don't want to floor it but I am excited and tempted. Get to my offramp lane and punch it. 60 to 100 just like that! Just like old times. I floored it 5-6 times more between the freeway and home and all seems OK. No codes or CEL.
I know a lot of you guys are way more experienced in the workings of these cars than I am. Any thoughts or ideas on my car that appears to have fixed itself? I am definitely going to drive it more now!
Old Nov 3, 2012 | 12:35 PM
Default Re: My SRT6 fixed itself by being driven! Hopefully....
Wild guess : condensation in the electronics part of the TB ( TPS etc. ).
There is a Resistance circuit board with wiper contacts in there.
Warming it up and driving a while would cure that.
Old Nov 3, 2012 | 01:00 PM
stryfox's Avatar
just a thought, On my old limited I installed a sprintbooster.
It would do exactly as you described, I sent the sprint boster back and got a replacement one and it never did it again....
Just adding some info if it helps you or others....
Old Nov 3, 2012 | 01:08 PM
NeedsWings's Avatar
pull off sprint booster if you have one, get a new tb if you dont
Old Nov 3, 2012 | 03:36 PM
steverwrx's Avatar
No Sprintbooster. I hope Alaxfire is right
Old Nov 3, 2012 | 05:41 PM
corrosion or moisture will cause resistance. which will cause a high voltage or amps due to the resistance. It may have solved itself. That's why you need to drive them even if it is just around the country mile to gets things warmed up... If you were driving this one more, I might be inclinded to agree with the others, but I think this one is from not driving it enough...
xfClifford
Mar 3, 2021 04:52 PM
PimpDaddy
Mar 31, 2020 07:22 PM
rperry52@live.com
Feb 14, 2019 12:18 PM
rmcdaniel12
Sep 26, 2016 05:37 PM
axnguyen
Jul 21, 2015 11:41 AM
