Can you drive the car w/65mm pulley before a tune?
Old Dec 24, 2012 | 12:17 PM
meh03's Avatar
Default Can you drive the car w/65mm pulley before a tune?
I've already gotten a EC tune with the NW CAI. I'm going to install the 65mm pulley. Can I drive it before the re-tune or would it be best to wait? I don't want to mess anything up with it burning too lean.
Old Dec 24, 2012 | 12:27 PM
Default Re: Can you drive the car w/65mm pulley before a tune?
You can drive it just don't do wot runs. You will be fine.
Old Dec 24, 2012 | 01:54 PM
meh03's Avatar
Any tips on how to stop the SC from turning to get the pulley bolt out? A leverage wrench and rubber pad isn't working.
Old Dec 24, 2012 | 02:20 PM
velociabstract's Avatar
I tried to follow the instructions and scared my self. Just go down to the nearest hardware store and buy a strap wrench. Cheap, easy to use and you won't run the risk of bending the supercharger snout. BTW, I was using my 65mm pulley for over a year without a tune. The stock programing is real rich. Since your already tuned that may not be the case. Better safe than sorry.
Les
Old Dec 24, 2012 | 03:15 PM
Yeah les he mentioned being tuned already. So they may have leaned him back some. The strap wrench is the safest method.
Old Dec 24, 2012 | 04:11 PM
meh03's Avatar
Ok, so I got it installed and now there a small amount of oil coming out from between the clutch plate and SC.
When I installed the new pulley, I removed all the stock shims and it is still 2mm (not the recommended 0.2mm) from the SC.
At first I used a new bolt from Needswings, but noticed it is solid, so I reinstalled the factory hollow bolt. The belt moves back and forth a little while running.
I'll call EC when they are open again. Any ideas on why it wouldn't seat close enough?
mls
May 22, 2021 04:12 PM
mjgroves
Jul 4, 2015 08:17 PM
cojoman
May 30, 2015 09:43 AM
lazorouss
May 29, 2015 08:28 PM
crossfiretech
Sep 25, 2003 08:14 PM
