Cut Springs
Old Jan 22, 2013 | 07:48 PM
AlbertFattal's Avatar
Default Cut Springs
We all know the rear of the SRT is a bit higher than it should be. Almost looks as though it is "tippy toe'ing" the rear wheels.
I'd like first hand experience from those who have cut their springs to lower the XF. I understand the spring is uni forced and the tension is the same throughout the spring.
Did it still deliver performance wise?
Old Jan 22, 2013 | 09:38 PM
JHM2K's Avatar
Default Re: Cut Springs
I tracked my Limited using cut SRT springs. So in a word, yes they deliver.
Ride is harsher, but the look is worth it. Eibachs look great but from what I hear, they're too soft for track use.
Old Jan 22, 2013 | 10:51 PM
How low did you cut? 1/4 a turn? Did you have to heat / seal the cut end?
Old Jan 23, 2013 | 12:32 AM
JHM2K's Avatar
Mine actually had a full coil removed, but that was the case on all four corners. If I were to do it again, I'd only remove 3/4 turn and see where it sits.
Heat sealing isn't needed, but some POR-15 or underbody paint wouldn't hurt to prevent rust.
Old Jan 26, 2013 | 10:45 PM
MBZDECOY's Avatar
today I changed the wheels on my CF, i have installed for a test 17" rim and higher tire to bring it to the normal, or close to normal position, what a diferent in the ride WAW, the car rides still like a sports car, but it "shaved" off all the little unplesant harsh jump over the little bumps on the road, and it makes the car much quiter.I love it. my dentures do not fall off any more....
55chevy
Jul 22, 2024 02:31 PM
onehundred80
Aug 6, 2016 12:03 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ayebb
Sep 18, 2015 03:35 PM
jaesa
Sep 7, 2015 01:50 PM
