Valve Cover Bolts Torque?
Old Feb 1, 2013 | 03:17 PM
meh03's Avatar
Default Valve Cover Bolts Torque?
I've done the research and from what I have found these should be torqued to 7 ft/lbs. But, is that for the smaller breather covers on top and the valve covers that sit on the heads?
I've got a film of oil between the valve covers and the heads (around the spark plug area). 36,000 miles and never re-tightened, so I'm going to try re-torquing before taking them off and applying new sealant.
Old Feb 1, 2013 | 03:43 PM
Default Re: Valve Cover Bolts Torque?
see post #2 in https://www.crossfireforum.org/forum...over-leak.html
Old Feb 1, 2013 | 04:19 PM
meh03's Avatar
Thank you.
Old Feb 2, 2013 | 08:06 AM
Buggin's Avatar
FYI, the valve cover uses a pre-formed rubber gasket. I would imagine a retorque should fix you up. I pulled mine to paint, so I just replaced the gaskets while I was there. Plus they are only $12.85/ea. from autohausAZ
55chevy
Jul 22, 2024 02:31 PM
maxcichon
Sep 25, 2015 02:55 PM
tritongreen
Sep 18, 2015 07:32 AM
lang
Sep 17, 2015 06:37 AM
RacerXofFL
Sep 15, 2015 05:00 PM
