2005 srt6
Old Mar 16, 2013 | 09:36 PM
SRT6-2005's Avatar
Default 2005 srt6
Hi I just bought a 2005 SRT6 With 122k and it looks like the Supercharger doesn't not work, I didn't really know how check if the Supercharger work, I just bought it like that, Now i know the Supercharger doesn't work, I'm not sure if its the Pump, or the Pulley.. can some one please help me. I don't have much money to fix it. I saved for 3 years to buy this car.,
Any help will help me a lot. the car doesn't not run strong as i though.
Old Mar 16, 2013 | 10:15 PM
JesseJamessrt6's Avatar
Default Re: 2005 srt6
From what I could interpret from you wrote above it sounds like it is the supercharger intercooler pump. It is located at the passaanger side very front bottom corner. Check the fuse for the pump, do a search for what fuse number it is and where it is located. To get access to the pump you will have to remove the wheel well cover/linning to see it. You can pull the pump, rev the car above 2,000 rpm and it should turn on.
180 has a great thread that is stickied in the forum.
Others have great write ups too. Take your time and do a search and read. It is worth your time on this forum, lots of good advice from mature experienced folks.
File Type: pdf
Old Mar 17, 2013 | 12:09 AM
SRT6-2005's Avatar
Thank you i will check that out. just in case if the Pump is bad do you know where i can get one at good price..? Also my super charger pulley start making a bit of noise. is it hard to replace it and where can i find.?
Thank you for your help. I really appreciate.
Old Mar 17, 2013 | 02:48 AM
FUBU's Avatar
Check needswings.com they have them for sure. Johnson cm30, DIY is on here aswell. Congrats on the new car. Check out and join the vin# gallery on SRT-6.com, also check that your car is listed in the vin# list here on the forum. (Search: vin) welcome to the club!
Old Mar 17, 2013 | 01:03 PM
The OEM pump is a Bosch and I think it has been upgraded. An aftermarket pump is a Johnson like FUBU pointed out above. Rob at Needswings has a lot of high quality parts at a reasonable price. He is very knowledgable and if it isn't listed on his website e-mail him and he can find out where to get the parts you need.
Artwork
As far as the SC pulley, look at an OEM bearing replacement in 180's list of common problem
https://www.crossfireforum.org/forum...tml#post713975
Old Mar 17, 2013 | 02:09 PM
SRT6-2005's Avatar
Thank you so much. i will check it out. I'm new on this I will learn as we go.
Old Mar 17, 2013 | 02:45 PM
dry contacts's Avatar
Hey congrats on the new purchase!! I found the updated bosch pump no.0392022010 for around $110 on amazon. I installed this one this past Tuesday with no problems. I went with this one cause its cheaper then the Johnson cm30 pump.
Old Mar 17, 2013 | 02:51 PM
syfi's Avatar
Here's the updated Bosch pump...w/ free ship
Mercedes Auxiliary Water Pump - Bosch (OEM) 0392022010 | FCP Euro
Old Mar 17, 2013 | 05:13 PM
Infinity's Avatar
Just a heads up. You may want to consider flushing the coolant system with some cleaner and have it sucked down. I have found that doing so keeps me from having issues with pumps and cooling issues with tuned motor. keeping the impeller vanes clear of any gunk will make everything work better.
Old Apr 16, 2013 | 08:06 PM
cudaman's Avatar
See also this thread:
https://www.crossfireforum.org/forum...osch-pump.html
Old Apr 16, 2013 | 08:20 PM
Damn I hope it was a great buy. Why do you think the s/c isn't working? What is it doing or not doing? Do you have intermittent power or no power at all? You have a temp sensor that can go bad as well. But with those miles replacing the pump isn't a bad thing.
itsky
Aug 4, 2015 10:35 PM
RiderJC
Aug 4, 2015 10:25 AM
itsky
Aug 1, 2015 03:45 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
RED DOG
Jul 22, 2015 08:55 AM
