65k miles on my SRT, IC pump failing??
Old Mar 20, 2013 | 01:24 PM
brooklyn23$'s Avatar
Default 65k miles on my SRT, IC pump failing??
Purchased my SRT at 30k for the next 30k it ran like a dream, i could unleash it whenever i pleased. Now at 65k it does.not have the same performance, at highway speeds or even at dead stops it lacks significant acceleration and sometimes it feels like.im driving a nkssan sentra instead of an SRT.vehicle. the problem is intermitent, what could it be? Ive replaced the throttle body, SC pulley, air pump, SC clutch, crank.sensor and plugs and still no fix... please help.
Thank you
Old Mar 20, 2013 | 01:48 PM
FUBU's Avatar
Default Re: 65k miles on my SRT, IC pump failing??
try do a throttle reset, but for sure I would guess the IC pump needs to be changed.
Old Mar 20, 2013 | 01:58 PM
Default
Thank you, i believe the main culprit here is that infamous bosch pump which seems to only last 25k-30k on these SRT's. Have u replaced urs? If so, which pump would u recommend?
Old Mar 20, 2013 | 05:22 PM
Buggin's Avatar
Thank you
I'm confused, you replaced a bunch of stuff (some not related to the problem), but not the most common failed item?
I replaced mine with an updated Bosch and been running strong for 65k miles so far.
Old Mar 20, 2013 | 07:05 PM
Default
Yes, i should have signed on the this cfireforum a long time ago, ive spent countless hrs and had numerous headaches trying to find the root of the problem. I took my car to MB tech shops and theyre the ones who advised to replace all the mentioned parts. I set up an apptment w a shop to replace my IC pump tomorrow, hope it works.
Old Mar 21, 2013 | 04:01 PM
God_Likes_Tebow's Avatar
Where did u get an updated bosch one? I think my Johnson is starting to fail.
Old Mar 23, 2013 | 09:31 AM
Buggin's Avatar
I actually used the updated Bosch pump for the Ford Lightning/Cobra. But then you have to swap over the outlet end and connector. I've been told the Bosch unit now for sale as OEM for The SLK/SRT is now the updated unit also. I've got my old one to verify the old part# if you need it.
Old Mar 23, 2013 | 12:05 PM
Bigkid's Avatar
Rob at Needswings has the up dated Bosch pump.
RED DOG
Jul 21, 2015 07:58 AM
leaddog2015
Jul 13, 2015 12:25 PM
tom2112
Jul 12, 2015 04:41 PM
GWAPA
Jul 8, 2015 07:25 PM
bradleykologek
Jul 6, 2015 02:49 PM
