Why Woody did not get the srt to Pa, blowed up
If you rip up the drag strip a lot or something similar I can see future problems. When the pros do something like this they test the parts and replace any found to be failing. Amateurs wait until the part fails and then whine - just like the failing diffs.
I cannot see the average smuck having anything to worry about.
We will be putting a diff cooler on in the next few weeks. I'll pass the info on to Rob and it'll be up to him what he wants to do.
You are incorrect, it is common practice to stress a part to failure. If you don't know where the failure point is there is no sense testing a part to begin with. Common sense tells you to replace a part that is showing wear, but internals are not constantly checked with the exception of F1, some Rolex teams and perhaps Nascar.
Everyone knows that parts are routinely stressed to failure.
What is the point of testing something as you say when you know when it will fail. Why would you bother, just to prove you were correct?
I thought I had said that the pros check and replace parts before they fail in use.
Anyway, any discussion with you is liable to get you to delete all your posts on the subject, just as you did last time.
Finally something we agree on
Your current statement could be said to be somewhat contradictory, parts are replaced when they are deemed to have come to the end of their stress life based on calculations and field experience. No failure indicators may be seen, but it is only a matter of a little time and POOF it's done. Carrying on to failure can be fatal. The bigger the budget the more tests and the more new parts can be used. Losing an expensive piece of equipment for the cost of a part is false economy.
I am not an accountant or a laborer having worked in the engineering field for close to sixty years, so I do know of which I speak.
When I had my wavetrac installed - the installer was suprised I went for the 75/90 instead of the 80/140. I'd already bought it ($90 bucks here for 2Qrts) and changing the oil down the track is a real DIY so I was heading that way latr.
My Ring and pinion gear was worn and he made a point of telling me if there's a whine after install its due to that. He offered to take me for a drive pre-install to show that it was already there - but I took his word on it. He indicated it was evidence of a lot of highway driving at 55mph (previous owner).
The spiders were also slightly worn - but due to the wavetrac, the ring and pinion were the only ones replaced.
I still have the old spider gears downstairs in a box so if I can help with a photo - let me know.
He was also actually suprised how bad the OEM oil was after 80k miles when they drained it. I guess that's evidence that there's a lot of heat being generated in these babies at highway cycle.
b22b
http://i313.photobucket.com/albums/l...t/P1070894.jpg
Saw this pic. of a diff. cooler kit and wondered if anyone has done anything like this on one of our cars. I know that a couple of years ago Rob had asked Forum members if there was any interest; and there didn't seem to be any. He mentioned that he had parts all picked out for a kit for us. I think it was expected to be over $1K IIRC.
OEM should recomend a brake-in oil change for the diff after x# of miles or within the first year of new car ownership. IMO
Well, I listen to those who actually perform with their cars rather than speculate. I installed at 32k on the roadster, and 26K on the coupe. Everything looked OK, but we didn't mic anything, so who really knows. I haven't had any problems to date, but the coupe does have a little more noise than the roadster. I think a cooler, and a temp gauge is a good idea. We run them in the big rig on the both diffs. Gives you some warning on bearings and such, but wouldn't be any help with ring and pinion cracking. I can't fathom the temps being high enough for this problem to be happening. I think heat treatment or torque load is causing this to happen. Hopefully it is just happening to round trackers...lol....
I will be boxing up the rear and shipping it to the coast in a week, for gears, bearings, assembly and shot peening. When I get it back I will be looking at a way to add a cooler to it. I plan on chilling the case some with a water line tied to my super cooler. There is ample cooling capacity there and a low pressure line should not cause any issues. It will assist and I will be the first to agree it is not optimum, but I have been bringing creations forward like the oil separator, pulley saver, and S/cooler, even before there was a demonstrated need.
Should be possible to get some gain, and of course I will be instrumenting it for proof of the concept. Just have to finish the house and garage before the weather comes in, I hope.
Yall be well. Woody
Yall be well. Woody
Woody, I don't know how you do it....I remember working on this place 12 yrs ago. I couldn't nor wouldn't do it again.... I can't find time now to even work on the cars....let alone the house. Just lucky to keep up with the maintenance... Good luck to you, God's speed...
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
waldig
Jul 15, 2015 02:05 PM
