Screaming Noise
Old Jul 23, 2013 | 03:54 PM
miscetera's Avatar
Default Screaming Noise
So this morning on my way to work, my SRT-6 suddenly began screaming. The noise was embarrassingly loud, high pitched, constant at any speed / RPM, not really a screech like a belt though. After a mile or two, it stopped just as abruptly as it started and the car sounded and drove as normal for the rest of the trip. Thoughts? Mileage is right at 79k.
Old Jul 23, 2013 | 04:32 PM
Default Re: Screaming Noise
Most likely an idler bearing on the serpentine belt, or the tensioner.
Could be the SC clutch or bearings too.
Water pump ?
Alternator ?
Power steering pump ?
Old Jul 23, 2013 | 05:35 PM
Goldwing's Avatar
My wife screams every time I punch it off the line. It is not a pleasant noise.
Old Jul 24, 2013 | 05:40 AM
Buggin's Avatar
If you are running the stock pulley setup and have never changed the SC Idler pulley. That would be my first guess. It's the little one to the left (looking from the front) of the Main SC pulley.
Old Jul 24, 2013 | 05:49 PM
beasticles's Avatar
Your idler pulley is the very likely culprit. The bearing is likely shot. Search for my thread on this subject from this winter. Good luck!
Old Jul 24, 2013 | 07:30 PM
velociabstract's Avatar
If it screams at every start up and while stopped at red lights it "could" be the secondary air injection hose has popped off the pump. Mine was driving me crazy until I saw the hose unplugged. Plugged it in and no more screaming. Of course, yours could be another type of scream.
Les
Old Jul 25, 2013 | 02:01 AM
itsky's Avatar
My roadster would make a hideous noise about 20% of the time. Once I installed latemodel21's PSK, no more issues. I bet it is the idler pulley.
Old Jul 25, 2013 | 02:31 PM
miscetera's Avatar
Took it in to the shop yesterday and told them to check the idler pulley first. You guys were right on the money. Also replaced a busted motor mount which I was expecting based on what I've read here about movement in the shifter. Front brakes were nearly gone so I got those done. Throw in a pair of wiper blades. Everything OEM. $1,188. I love my car, so it's all good. Thanks for pointing me in the right direction!
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
