20 inch rims PLEASE HELP
Old Aug 3, 2013 | 07:27 PM
austinbarrylee's Avatar
Default 20 inch rims PLEASE HELP
I am purchasing a srt6 with eibach springs. I was wondering can I put 20x9 35 offset for the front and 20x10.5 38 offset wheels. Or should I go with 19 in front and 20 in rear. Everyone knows 19 inch rims are hard to find. THANK YOU FOR HELP
Old Aug 5, 2013 | 09:04 PM
cudaman's Avatar
Default Re: 20 inch rims PLEASE HELP
Those Eibach springs are going to make the ride more harsh than stock. Combining that with oversized rims with even less sidewall is gonna make it even more harsh. If that's your cup of tea, go for it. For the price of the rims/tires you might get consider getting a set of coilovers that are dampening/compression adjustable. The KW-V2's that I have are great even if they are only compression adjustable. WAY more comfortable than stock or Eibachs, lowered 1.6 inches, handles great, even though stock handling is pretty good to begin with. You will save money as the KW-V2's are like $1600. You will need rear control arms and either camber bolts ($60) or KMAC camber kit($430 - pretty expensive) in front unless you like a lot of negative camber (which you may already have with the lowered Eibachs). Check out the thread on "lowering" on this forum. Some good suspension guys chime in there.
Old Aug 5, 2013 | 10:19 PM
thanks for the help cudman. the car im buying already has the eibach springs on it. i was just wondering about rims. i am going to put koni struts on it.
Old Aug 10, 2013 | 05:52 AM
shawndalyphd's Avatar
Default
I have:
18x8.5 +35
19x9.5 +35
The difficulty in the front is always the suspension bolt on top of the wheel. As you're planning to stay the same offset, you won't have any problem rubbing, just sticking outside the wheel well. In the rear, the space is gained by going to higher offsets. My +35 look absolutely stock, in terms of where they are placed in the wells. My guess is that they will house absolutely monster wheels, with the higher offset. People have put 305's on +35's.
Hope that helps.
Shawn
TerryR
Dec 13, 2019 03:27 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Power Sedan
Sep 20, 2015 09:24 PM
caseydeankopp
Sep 13, 2015 07:25 PM
jaesa
Sep 7, 2015 01:50 PM
