Safely use drag radials
Old Aug 14, 2013 | 12:15 PM
Baker12673's Avatar
Default Safely use drag radials
Hi im new to this forum and looked around before posting this but I can't seem to find out what needs to be upgraded or beefed up to use drag radials at the track.. What should I go with so I don't snap anything on hard launches like axles or things of that nature. Thanks for the feed back
Stock with the dr's and then modded srt6 is what I'm looking for
Old Aug 14, 2013 | 02:29 PM
ImportLabSRT's Avatar
Default Re: Safely use drag radials
You don't have to worry about axles, they are pretty stout. Over time, you will need to worry about the rear diff eating itself alive. I run 275/54R17 Hoosier drag radials that hooked very well when I was still supercharged and running 12.0's. I spin them on the 1-2 shift now if the track is cold or poorly prepped.
Old Aug 14, 2013 | 02:38 PM
Baker12673's Avatar
Default
So for modded and stock just watch out for the rear diff? And your times was that just with slicks or did u have other mods
Old Aug 14, 2013 | 05:05 PM
velociabstract's Avatar
I never got the hang of launching with street tires. Best was 12.750 I think. With drag radials I run consistent 12.0's.
Les
Old Aug 14, 2013 | 07:45 PM
Eurocharged 181mm pulley, Needswings CAI, Needswings Supercooler, DIY cooling system separator, Eurocharged dyno tune, and Hoosier DR's.
Never ran the car at the track with the custom header-back exhaust, Needswings Intake manifolds and Eurocharged 185mm pulley.
Old Aug 14, 2013 | 08:15 PM
blackpepper's Avatar
hey les did you use your stock wheel studs are a aftermarket set if so what type
Old Aug 14, 2013 | 08:24 PM
I was using stock type bolts of different lengths until recently. The studs I have are 80mm and I purchased both ball seat and conical seat lugs. The studs are long enough for a 5mm spacer. The studs I used are from this company.
Mercedes - Wheel Stud Conversion Kits - Motorsport Hardware
Les
Old Aug 15, 2013 | 09:38 AM
Baker12673's Avatar
Default
Les
So the soon to be my srt6 is going to be the first car I'm using dr's on what do I need to make it last... You guys talk about studs and lugs what's there function
Old Aug 15, 2013 | 11:47 AM
NeedsWings's Avatar
here is the easy solution...
Drag Radial Package
rmcdaniel12
Nov 4, 2015 04:08 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Ralph289
Sep 21, 2015 09:34 PM
rmcdaniel12
Sep 21, 2015 10:58 AM
Vegaslegal
Sep 10, 2015 11:24 AM
