rear hub/half shaft removal?
Old Nov 13, 2013 | 02:18 PM
Raz83's Avatar
Default rear hub/half shaft removal?
Changing out rear passenger side wheel bearing I removed everything including the half shaft nut but the half shaft won't budge the service manual is different from our shaft set up can anyone walk me through removing it please.
Old Nov 13, 2013 | 02:30 PM
Default Re: rear hub/half shaft removal?
Wish I could help, as far as I recall some are slide in and some are bolted to the diff. To be frank I could be wrong altogether but ...
I'll look it up, got to refresh the memory here.
Old Nov 13, 2013 | 04:57 PM
hustler316's Avatar
You have to hit it with a dead blow, there is a retaining/locking ring inside the diff. Hit it so that the shaft comes out of the diff...just give it a good whack
Old Nov 13, 2013 | 05:06 PM
Raz83's Avatar
Thanks guys any input is welcomed
So do I hit the hub itself or is there something else I'm missing also I didn't remove the dust shield does hat have to come off?
Old Nov 13, 2013 | 05:43 PM
hustler316's Avatar
I actually thought you were removing it from the car, after rereading you are just removing the hub correct? If so give the end of the half shaft a whack, just make sure it is a rubber mallet. Also you have to get new half shafts nuts, they are not reusable. I assume you have everything disconnected from the hub already? When you re-install the half shaft make sure you have a big enough air impact, the torque of the axel nut is what sets the preload on the wheel bearing.
Old Nov 13, 2013 | 05:50 PM
Raz83's Avatar
Only things I removed were the brake rotor,and brake caliper and of course the half shaft nut
PNA
Nov 12, 2020 04:44 PM
amx1397
Jan 24, 2016 02:12 PM
sittininthesun
Aug 24, 2015 10:47 AM
Tp'sfury
Aug 13, 2015 08:20 PM
velociabstract
Aug 7, 2015 01:30 PM
