S/C pulley noise?
Old Dec 9, 2013 | 03:54 PM
scomer88's Avatar
Default S/C pulley noise?
I have been hearing some noises coming from my engine and decided to see which pulley. I removed the belt and tried spinning them by hand. It appears the S/C pulley is the culprit. I am looking at just going with the Eurocharged 65mm pulley but i want to make sure that its just the pulley and no the actual S/C. I am linking a video of me spinning the pully without the belt. All other pulleys spin correctly. Also just installed a NW pulley saver kit anyways which installed very easily.
video 2013 12 07 15 12 43 - YouTube
Old Dec 9, 2013 | 04:22 PM
grip grip's Avatar
Default Re: S/C pulley noise?
Definitely the bearing.
Old Dec 9, 2013 | 04:23 PM
scomer88's Avatar
Thats what i was thinking, just wanted to get some more opinions. Thank you. Will the Eurocharged pulley come with a bearing already or will i need to buy one?
Old Dec 9, 2013 | 04:41 PM
RED DOG's Avatar
I see you already have the PSK so it's definitely a bad bearing in your supercharger pulley. You can buy a new bearing from Needswings and then have your local NAPA (or wherever) press out the old bearing and press in the new bearing. I would suggest you do that while your deciding to upgrade to a 65mm pulley or not (don't run it with a failing bearing). Full repair on the OEM pulley should total under $75.00.
Old Dec 9, 2013 | 04:53 PM
grip grip's Avatar
The EC pulley includes the bearing.
Old Dec 9, 2013 | 10:24 PM
Tp'sfury's Avatar
Yes, unfortunately that is the SC bearing. Same thing happened to me just a few months ago. I went with the EC 65 mm SC pulley and am VERY happy with it. You will also need to purchase a tune with it . Not exactly a cheap fix but the noise will go away and you will feel a big difference!
rmcdaniel12
Nov 4, 2015 04:08 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
