Rub out on Fender.
Old Apr 8, 2014 | 10:17 PM
hayirichie's Avatar
Default Rub out on Fender.
I rubbed my inner rear fender and fish tailed as I was going around a corner where the road elevation changes. It also put a nice cut in the tire and damaged the fender wall. I have been running a 255/35/19 rear with a 20mm spacer. I had no issue with rubbing at all prior to this. I just installed new kyb's KG4732 and KG4731 shocks with 275/35/19 hankooks rs3. The kyb seems to ride smoother but softer. If I stack the stock and kyb bushing will it make a stiffer ride? Will running 275 rear without a spacer still run a risk of rubbing the fender walls?
Old Apr 9, 2014 | 06:15 AM
Thornh's Avatar
Default Re: Rub out on Fender.
I am running 173/35/19 Michelin AS3's with no spacers and no rubbing issues on a SRT-6 with stock suspension. Not sure if you will still have an issue if you are lowered. Search the forum, there is lots of info here about tire sizes and issues.
Old Apr 9, 2014 | 07:08 AM
Where did you get those ? Must look like bicycle tires on the rear, pictures please.
Old Apr 9, 2014 | 08:59 AM
Thornh's Avatar
Sorry , typo should read 275/35/19... Was too early this morning when I posted that LOL!
Roty135
17
Oct 11, 2018 10:11 AM
MiamiTVR
Jan 30, 2016 02:15 PM
velociabstract
28
Oct 28, 2015 12:46 PM
gblack32
Sep 30, 2015 01:13 AM
RiderJC
Sep 7, 2015 11:19 PM
