wavetrak advise please
Old Apr 13, 2014 | 07:28 AM
cooee's Avatar
Smile wavetrak advise please
my wavetrak arrived yesterday Is there any advise on the best way to fit it into my 2005 srt
im replacing the flexi disks and tailshaft support at the same time
drag season starts shortly in Australia
best so far 12.1 nearly at the 11s
Old Apr 13, 2014 | 06:11 PM
Billy22Bob's Avatar
Default Re: wavetrak advise please
Is it already fitted in a diff case or just the new internals from Wavetrak?
I had my internals fitted by a gear and diff specialist mech. south of Sydney.
I had all my bearings replaced as well. I bought these as a 2nd delivery (after thought) from Wavetrak.
total labour = $800 - ouch
Old Apr 13, 2014 | 11:40 PM
if you ordered the wavetrac only and plan to install it into your diff here are a thing or wto to look for AS YOU CAN DO IT YOUR SELF.
after the diff is out of the car, and on the bench
HAND TURN THE YOKE GET A FEEL OF IT YOU WILL NEED TO DO THIS AGAIN AFTER INSTALL.
remove the SNAP rings keep left on the left and the right one on the right as the snap rings are the shims.
so now remove the center section, move the ring gear to the wave trac ,, you will have too get new bearings and races,install them
install the center section back into the diff housing,,,install the snap rings, hand turn the yoke, if it feels as it did when you first removed it , your ready to install the rear cover and put it back in the car,
note: the wavetrac is made to be within .007 of the factory unit. so if it is hard to turn take a brass bar and smack one of the the snap rings that will either tighten or loosen it up, then smack the other side it should center everything up and now turn like it did when you removed it. good luck, you really don't need it as this is simple to do. jim
Old Apr 14, 2014 | 11:46 PM
cooee's Avatar
thank for the tips jim will have it up and running soon
3more weeks till state titles (drag racing)
look out 11 here I come well hopefully
as I point me down the strip
I pray to god to give me grip
if my grip should fail at all
I pray like hell keep me of the wall
toob
Sep 26, 2015 11:44 AM
crmnal
Sep 6, 2015 08:07 AM
Bayukbros
Aug 28, 2015 08:59 AM
Wolf_7
Aug 26, 2015 06:37 PM
Diabla
Aug 20, 2015 10:50 AM
