HELP! Transmission quit working
Old Apr 15, 2014 | 12:57 PM
meh03's Avatar
Default HELP! Transmission quit working
This morning I drove my srt down the street a bit and all of a sudden the transmission dropped out of gear. No gears work except park. I put it in drive press the gas and it just revs, same with reverse and it won't shift manually. I've never had any shifting problems. I haven't noticed any fluid on the garage floor. I had Speedriven program the TCU a while back. Can anyone help?
I'm going to try disconnecting the battery. Haven't seen any engine lights yet.
Old Apr 15, 2014 | 01:27 PM
firstshadow's Avatar
Default Re: HELP! Transmission quit working
Check tcu and wiring for oil and check your transmissions oil level
Old Apr 15, 2014 | 03:15 PM
Billy22Bob's Avatar
you could try ye trusty old transmission reset....
get in car - key to Pos 2 - foot on the accelerator for 5secs past the kick down - with foot still down on accel, key to Pos 0, lift foot off accel. and don't touch anything for >120seconds, remove key. Then simply try to start car as normal.
Old Apr 15, 2014 | 03:34 PM
meh03's Avatar
I'll try the reset (that would be nice if it worked) and check, disconnect/reconnect the TCU after work. I tried disconnecting the batter and nothing. It's weird the transmission won't engage at all.
Old Apr 15, 2014 | 03:47 PM
meh03's Avatar
I just read the computer and got code P0730 which appears to be improper gear ratio.
Old Apr 15, 2014 | 05:26 PM
Billy22Bob's Avatar
disconnecting the battery I think requires a certain number of minutes before it invokes the factory defaults reset in the tranny upon reconnection....15mins?...someone else more studious can maybe chime in.
Old Apr 15, 2014 | 07:12 PM
Speedy4x4's Avatar
Default
I have not done it on XFire but other vehicles disconnect neg battery terminal for 15 min
Old Apr 15, 2014 | 07:43 PM
RL67037's Avatar
I've had that code before - improper gear ratio - my car wasn't going out of gear but it was going into limp mode a lot. My car had over 70K miles on it and I doubt the transmission had ever been serviced. Had the fluid changed and the system back flushed and the problem has never returned.
Old Apr 15, 2014 | 09:40 PM
meh03's Avatar
What is strange about this is it has never had problems. Never gone into limp mode. Shifts as smooth as butter. No warning just no gears all of a sudden. I tried disconnecting the battery, transmission reset, disconnect and reconnect tcu. Trying the battery once more before the toe truck gets here. Very disappointing.
Old Apr 15, 2014 | 10:18 PM
tunaglove's Avatar
Default
I second this advice.
Old Apr 15, 2014 | 11:45 PM
rcompart's Avatar
When you shift it into drive or reverse and apply throttle, are you saying the car physically doesn't move at all?
Old Apr 16, 2014 | 09:43 AM
meh03's Avatar
Hi Rudy. Yes, correct. When you shift into drive or reverse, it displays as such on the dash but no movement. It doesn't even give the slight bump of engaging the gear. It's as if the transmission is not recognizing it is being put into gear. Revs as it would in park.
Old Apr 16, 2014 | 09:48 AM
rcompart's Avatar
PM me your number and I'll give you a call shortly if that is convenient for you.
Old Apr 16, 2014 | 09:54 AM
rcompart's Avatar
BTW, forgot to ask, can you have someone try to push the car forwards or backwards while you're sitting in it with the car in drive or reverse to see if the parking pawl is actually being released?
Old Apr 16, 2014 | 10:31 AM
'toe truck' - hilarious.
have you jacked it up to see if maybe one of the flex couplers on the driveshaft have disintegrated ?
( if it won't move when in Park and the emergency brake is not engaged, then never mind )
Old Apr 16, 2014 | 10:32 AM
meh03's Avatar
I can tell you I was going down hill when it happened and with it in drive it rolled freely with no acceleration when pushing the gas.
Old Apr 16, 2014 | 10:39 AM
rcompart's Avatar
I asked about the parking pawl because I was very optimistically hoping that the shift linkage had perhaps came loose when shifting to park but I didn't read your first post correctly to see that it happened while you were actually driving it.
I'm guessing a spring in your valve body broke so there is no engagement pressure or one of the solenoids in the transmission died causing essentially the same thing. If they say it's either, let me know because for what it will cost for them to repair/replace with OE parts, upgrades will be the same or similar price.
Also, got your PM so I'll call you shortly.
Old Apr 16, 2014 | 10:57 AM
How much does it cost to get a toe truck? I heard they charge by the foot.
Old Apr 16, 2014 | 11:11 AM
We don't cut 'em slack, eh Dave ?
Old Apr 16, 2014 | 11:35 AM
No, gotta nail 'em every time, but it makes me feel like a heel sometimes.
