All Engine Motor Transmission Mounts Failed 65k miles
Old Jul 10, 2014 | 10:31 AM
snpiee's Avatar
Default All Engine Motor Transmission Mounts Failed 65k miles
OK, so after reading some threads on engine mounts failing on crossfires as well as SLKs, I decided to check mine out. Well what do you know, not one ,not two, but ALL THREE are busted! I took out the drivers side out yesterday, its completely ripped in two parts. The transmission looks pretty bad too. I haven't taken the right side out but I can see that it leaked. So I'm on a lookout for replacements. Found this set on ebay. Its listed as for C240 but my gut tells me its gonna be the same or close enough to ours. Do you guys agree?
Old Jul 10, 2014 | 10:47 AM
S. Artee's Avatar
Default Re: All Engine Motor Transmission Mounts Failed 65k miles
Make it easy on yourself: Engine Mount Set
Old Jul 10, 2014 | 11:01 AM
snpiee's Avatar
LOL thanks that is easier but much more $$$$
Old Jul 10, 2014 | 11:10 AM
This is the Mercedes part number for the engine mounts A 270 241 04 13.
http://www.ebay.com/itm/CHRYSLER-CROSSFIRE-ENGINE-MOTOR-TRANSMISSION-MOUNT-MOUNTS-04-05-06-07-08-SET-3-/170866671497?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACrossfire&hash=item27c8727f89&vxp=mtrMay show shipping to Canada, ignore that.
Old Jul 10, 2014 | 11:18 AM
snpiee's Avatar
Thanks for your input. I went with this one since it is listed as compatible and looks the closest to original. I will let you know how they fit/look/work after I install them.
Old Jul 10, 2014 | 01:17 PM
Don't go too cheap or you'll be doing it again really soon.
Of course you'll be able to do it quicker then.
Old Jul 12, 2014 | 07:50 AM
Billy22Bob's Avatar
ok - so not enough vigilante's out there to retest the E55 mounts in the timelord thread....
Old Jul 12, 2014 | 10:18 AM
S. Artee's Avatar
Maybe he didn't know about it. I know that I didn't...
Old Jul 14, 2014 | 01:59 AM
Billy22Bob's Avatar
cool....link here
Old Jul 14, 2014 | 12:44 PM
Please keep us in the loop, I need to replace mine as well....
Old Jul 14, 2014 | 11:13 PM
snpiee's Avatar
UPDATE:
I got the mounts today. At first I was pretty pissed what I got is not what was advertised in the picture. In the picture they looked more like the originals. What I got looks like the mounts for E55. They are slightly taller - maybe 3/8". I think some of that height due to being new and not having been compressed over time. I might be wrong. Anyways, these seem to be exactly what TimeLord installed. So I figured since these were made for the V8 they must be better. That logic in mind I went on the great adventure of replacing the engine mounts. Let me tell you, this is not for the faint of heart. It took me about 4 hours (including some time cursing german engineering) but I got it. The hardest part was loosening and then tightening the top mount bolts. What a PITA. It was especially hard to tighten them. I also used thumb ratchet on top when loosened. I raised the engine with a jack and a 2x4 across the pan to spread the load ( I know not the best solution, but the pan is cast aluminum with reinforced ribs). For the left, had to disconnect the steering strut and took out 2 retaining bolts for the rigid transmission fluid line. For the right took the mount out and put it back in through the area between the alternator and the mount. Had to take out the steering heat shield for more room. Old ones came out easier than putting new ones back with the exception of the right side - very easy. Will do the transmission mount next.
Old Jul 14, 2014 | 11:18 PM
snpiee's Avatar
Those of you that filled the transmission mount with urethane, did you notice more vibration? The way I see it, if you fill it you make it less flexible.
Old Jul 22, 2014 | 08:54 AM
snpiee's Avatar
So I have all the mounts replaced now including the transmission mount. Even though they were slightly taller (including the transmission mount) everything fit well and engine runs good and I don't see any clearance issues.
Old Jul 23, 2014 | 08:07 AM
Thanks for the info!
Old Jul 23, 2014 | 10:47 AM
snpiee's Avatar
You're welcome. I get alot of usefull information from this forum and glad to provide something back.
wootto
U.K.
Aug 16, 2020 07:55 PM
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
RED DOG
Jul 22, 2015 08:55 AM
Rusty475
Jul 13, 2015 10:03 AM
