Is installed the IC pump still doing same thing
Old Aug 4, 2014 | 04:30 PM
truecarolinablue51's Avatar
Default Is installed the IC pump still doing same thing
I installed the new IC pump from NeedsWings and the car is doing the same thing. I can turn the car off and start it back and it it runs Great for a minute and then goes into limp mode. I installed the pump refilled the fluid lost and that was it. Am I missing something here? I feel like the pump is not even running. I checked fuse 13 as well and it's good. Any help would be greatly appreciated.
Old Aug 4, 2014 | 06:13 PM
Default Re: Is installed the IC pump still doing same thing
Nevermind. Clamped off the return hose just before the T with a pair of vise grips and let it idle for 20 minutes. All is good! Runs like a rabid ape in Africa chasing a banana truck. So happy with this car! I swear it's just as fast as my dad's stock 392 SRT Challenger.
Old Aug 4, 2014 | 07:44 PM
Billy22Bob's Avatar
I found that I take the small bleeder hose and run it into a 1qrt drink bottle - and squeeze the hose as you mentioned, you can fill the bottle numerous times and simply put it back into your coolant tank.
Old Aug 4, 2014 | 08:35 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Faster by my experience.........(RIP 392 Yellow Jacket)
Old Aug 4, 2014 | 09:30 PM
Billy22Bob's Avatar
yes - but with the bottle I noticed it coughed and spluttered few a bottle or 3 before settling down.
Also you can gauge the number of micro bubbles floating around - quite amazing. I noticed this in my little pump test rig as well.
I'm only running the 2GPM Lightning pump ATM in the car, but have a 5GPM Pierburg CWA50 under test in the rig..
PS - I'm not sure if its an SRT6 thing, but the IC pump on my SLK32 wasn't working for months and I noted IAT's of 80+C (180F) in my logs and my SC (and car) just kept cranking. Mind you I only register 5-5.5 sec. 0-62's but no hick ups lumps or bumps in performance.
I have a new pump now.
Old Aug 5, 2014 | 01:57 AM
Are you saying the crossfire is faster than the srt392? I need to line up beside my dad and see.
Old Aug 5, 2014 | 04:42 PM
SouthernBronco's Avatar
I can testify first hand on SEVERAL occasions that the srt6 is faster than any srt8
Old Aug 5, 2014 | 05:30 PM
IF you have an SRT6, yes, it is faster....
Old Aug 5, 2014 | 07:48 PM
podea's Avatar
I'm having the same problem; new pump, double flush and filled.....
Could it be a I/C priming issue? What's the best way to be sure the I/C is full? (primed)
Didn't quite understand the quart bottle trick on a previous post; please advise.
Old Aug 5, 2014 | 08:11 PM
Billy22Bob's Avatar
see if the pictures help
PS - my install is probably not as pretty as others as I cut the old connector off to connect the new pump (with pigtails).
However this allowed me to hot wire the pump using the battery as shown.
If you have a neater solution with OEM plugs, I'm not sure how you can hot wire the pump.
Old Aug 9, 2014 | 07:33 PM
The vice grips did the trick for me. I let the car idle for 15 minutes and it started working like a charm.
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
Jul 17, 2015 07:21 AM
