auxiliary air pump
MB p/n A0001404385
BOSCH p/n 0580000017
Chrysler wants $750, M/B $450, Bosch on Ebay $229
New Genuine Bosch 0580000017 Smog Air Pump for Mercedes Germany | eBay
But before you replace it, here's a nice in dept article explaining a fix ...
http://mbworld.org/forums/c32-amg-c5...-pump-fix.html
thanks for the link...
Are you saying sify that this pump is the correct one for the Xfire/SLK32/C32???
Check the codes and before spending any money on a new pump you need to make sure that your MAF sensor is reading the small amount of flow created by this blower. Buy some MAF cleaner and give that a try first. The blower is coming on when the engine is cold?
Here's another ebay listing for a cheaper brand (with no p/n) and the 288 different models it's compatable with...including XFires!
http://www.ebay.com/itm/New-Smog-Air-Pump-Mercedes-Benz-E-Class-CLK-ML-SL-S-CL-C-G-CLS-SLK-R-E320/371088826219?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D20131231133846%26meid%3D5bc806939c544b018aa1a58ce42b65f2%26pid%3D100010%26prg%3D20131231133846%26rk%3D1%26rkt%3D24%26sd%3D380843484252
Check through this thread. Other fixes involved a corroded ground and a clogged check valve that both fixed the problem.
https://www.crossfireforum.org/forum...-solution.html
MB p/n A0001404385
According to my research of online retailers and other threads, the Bosch # is the one that cross-references the M/B #. Prices very widely up to $1100 on Pelican Parts for the OEM M/B part. This M/B # seems to also be one that is widely used on most M/B models.
Hey Fred, can you change out the bracket with the OEM unit?
Hi ..... yea I checked that out they are made so different that there's no way to interchange parts at all ...
spare pump on ebay...well almost the right number...
1998 2008 Mercedes Smog AIR Injection Pump W163 R230 W210 W203 W208 W220 R170 | eBay
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
