Cranking no start SRT6
Old Sep 29, 2014 | 04:53 PM
Davidm781's Avatar
Default Cranking no start SRT6
U ello everyone back with a new issue haha. My car finally was running fine for about a month after replacing the CPS and camshaft sensor with bosch parts. Now alas I finally get it running right drive to work car ran fine came out and car would not start. Had the car towed home and have no idea what the new problem maybe. I tapped the negative and positive to together to reset everything the car started fine shut it off and now it will not start again. Bad luck I am moving to ND and planned on selling the car tomorrow cause I cannot drive it in four feet of snow! Any tips before I spend all tonight trying to trouble shoot it! Thanks everyone
Old Sep 29, 2014 | 05:50 PM
syfi's Avatar
Default Re: Cranking no start SRT6
If you haven't done this yet, do it. Link to fix.....
https://www.crossfireforum.org/forum...-no-start.html
Old Sep 29, 2014 | 06:09 PM
Davidm781's Avatar
Yea did thaT while I fixed the CPS and camshaft sensor but wondering if I messed it up or something who knows.
Old Sep 29, 2014 | 06:23 PM
velociabstract's Avatar
DJ fixes them with great success. I re soldered mine and failed. It took a new one to resolve my crank and no start problem.
Les
Old Sep 30, 2014 | 01:12 AM
Davidm781's Avatar
Yea I fixed all 3 at once so I can't imagine it is the CPS or cam shaft sensor. But I also don't want to dump morel net into this thing just to trade it in or sell it. I don't know is there any other way to figure out if it is for sure the RCM?
Old Sep 30, 2014 | 06:01 PM
Have you done the obvious and checked the connections? And the other obvious and checked the fuses? And the final obvious, and re-checked those solder joints w/ a magnifying glass....not your eyes...lol
Old Sep 30, 2014 | 06:16 PM
I just went back to your old thread and read thru it again as well as your problem here. Do you know for sure you are getting fuel? I would hate to think after all you have done, a simple fuel filter failing would be the problem. Fuel pump and fuel filter are under the rear end. Just for the hell of it, make sure the fuel pump is working and the fuel filter which also serves as a regulator must be working as well. These can cause starting issues as well. Although not as common as the other problems....good luck....
Old Oct 1, 2014 | 12:09 AM
tighed1's Avatar
Starting to see fuel pump relay coils going out. If car cranks but won't fire try spraying starting fluid (carb cleaner, something that burns) into the air intake then try to start. If it runs just for a few seconds then...
Old Oct 17, 2014 | 09:16 AM
Davidm781's Avatar
Alright so I fixed the problem I checked the fuel pressure as everyone suggested I had pressure but I had a feeling it was bad gas. So I drained all the gas and changed the fuel filter and it was extremely dirty. Replaced and put new gas in and it runs just fine. Thanks everyone for all the help.
Old Oct 17, 2014 | 05:46 PM
Cool deal......an easy fix.....
KDW4Him
18
Sep 1, 2021 05:47 PM
pioneer4x4
Jul 1, 2021 10:56 AM
rmcdaniel12
Sep 26, 2016 05:37 PM
Jul 29, 2015 06:13 PM
bdh
Jul 9, 2015 09:40 AM
