NeedsWings manifold retorque
Old May 24, 2015 | 06:14 PM
bdh's Avatar
bdh
Default NeedsWings manifold retorque
Question for anyone with NeedsWings manifolds with the cork gaskets, and I noticed the Tork looses up on the bolts and the lockwashers spread.
Wondering if you guys retork periodically or torque wants and leave alone?
Thanks Barry
Old May 24, 2015 | 07:07 PM
chuK_138's Avatar
Default Re: NeedsWings manifold retorque
We retorqued the bolts on Thumper's car a few days after reinstalling them. Only went up one ft-lb though.
Old May 24, 2015 | 08:51 PM
JEFASOLD's Avatar
Thanks Barry
Personally, I never liked the cork gaskets and went back to stock, others have done the same.
Old May 24, 2015 | 09:18 PM
dinasrt's Avatar
Same here. The first time in removing the manifolds after installing and running with the cork gaskets for several months, I was appalled by the "squeeze out" of the gaskets to the inboard side. The possibility of the cooked "squeeze out" breaking off and falling in seemed pretty apparent to me. Well, that's my experience w/ them anyway.
Old May 24, 2015 | 10:34 PM
bdh's Avatar
bdh
Every time I checked them they are loose a tiny bit. the last time I took my intakes off I torqued them once and left them. Where do you guys buy the stock gaskets from? And do you put anything on them like permatex.
I've seen copper spray mentioned but I haven't seen it in the stores here.
Old May 25, 2015 | 07:54 AM
velociabstract's Avatar
I went back to the stock metal gaskets too. No matter how careful I was the O ring gaskets would crush. I tried to make the cork gaskets work but just couldn't for some reason. You can find the copper spray at any auto parts store. Ask, don't look. Permatex is what I used. If the mating surfaces are perfect you won't need the insurance (copper spray) IMO. I used it because I managed to get some scratches in the surface with my one edged razor blade. Oops.
Les
Dec 2, 2015 12:49 AM
rogerlemoine
Oct 26, 2015 12:02 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
