IC Pump TEST ?
Old Oct 25, 2015 | 09:13 AM
Ralph289's Avatar
Default IC Pump TEST ?
Is there any way to test the IC Pump other than "seat of the pants" test or taking it off and inspecting the inside and bench test . Mine is less then a year old and car has seemed to lost some punch. Also if the IC Pump is not working would the SC clutch still lock up. (I have added a LED light that shows when the SC is engaged) .I am going to try a Throttle Rest today and see it that helps.
Thanks
Old Oct 25, 2015 | 10:41 AM
Ralph289's Avatar
Default Re: IC Pump TEST ?
Forget it !! I got my old car back and BETTER ! Since I did the Dual CAI I never did the Throttle Rest the PROPER way. Well did it right this time ! Could feel the difference as soon as I pulled out of the garage and the a few WOT passes and WOW .......I'm one happy camper !!!
Simple fix for once
Old Oct 30, 2015 | 06:32 PM
Billy22Bob's Avatar
might be worth listing your throttle reset steps - just to let others know.....
Old Oct 30, 2015 | 06:47 PM
Ralph289's Avatar
1. Get in your car close the door.
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position .
4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
5. Wait 2 mins. for a full alignment. (Some say don't even open the door for 2 mins...)
6. Drive the car as you always do.
PimpDaddy
Mar 31, 2020 07:22 PM
Bulldogger
Apr 29, 2009 01:15 PM
distantpulse
Apr 24, 2009 02:46 AM
huudoo
Jun 30, 2008 12:48 PM
jeremy
May 12, 2008 06:34 AM
