Nasty (as in bad) Sound
Old Jan 15, 2016 | 01:57 AM
Dementors's Avatar
Default Nasty (as in bad) Sound
I recently had a vacuum leak issue and replaced the intake manifold gaskets which fixed the issue. Then I noticed that that there was a low grinding sound coming from the supercharger. I took the belt off and sure enough the supercharger pulley bearing needed to be replaced. I replaced that yesterday and could tell an immediate difference with the new bearing - nice and smooth. So I reinstall the supercharger pulley and everything is looking good and then I hear another sound, (there seems to be a pattern developing here!).
I attached an iPhone video which I know does not give the best audio but it may be good enough to hear the sound. Does it sound like another pulley may be making a noise? It appears to be coming from the left side of the engine.
Thanks
File Type: mov
Old Jan 15, 2016 | 05:49 AM
Default Re: Nasty (as in bad) Sound
Have you taken the belt off and turned each pulley/idler/tensioner by hand ?
Kinda sounds like the water pump to me.
Old Jan 15, 2016 | 10:04 AM
Dementors's Avatar
More updates. Drove it around the neighborhood after checking a couple of things and dash lights went off, then Head lights, then the car. Replaced battery with a spare and runs good but battery light is still on. Going to get the alternator tested. Could the alternator be making that sound?
Old Jan 15, 2016 | 10:17 AM
Fer sure.
Anything with bearings could make that sound, and the alternator spins faster that anything else.
( War Eagle ! Boo LSU )
Old Jan 17, 2016 | 10:59 AM
pioneer4x4's Avatar
Definitely signs of no charging not a bad battery.
Old Jan 17, 2016 | 11:50 AM
Dementors's Avatar
I just noticed the "Boo LSU" comment as I have been so focused on getting the car issue addressed. See how you snuck that in.
Geaux Tigers!!!
Old Jan 17, 2016 | 01:00 PM
4drturbo's Avatar
Yup, I bet its the alternator. Bearing on it is bad.
Old Jan 17, 2016 | 05:26 PM
Does everyone realize that at 6000 RPM, the alternator is spinning at 22,000 RPM ????????
Old Feb 4, 2016 | 02:02 AM
Dementors's Avatar
The alternator was replaced and the issue with the battery not charging has been resolved. However, this did not correct the vibration sound I was hearing. After further research, it was the crankshaft pulley/harmonic balancer. I have attached the pictures so you can see what I saw. It looks like the rubber fill was separating and moving through the back of the pulley so it was difficult to see what was going on when it was still mounted. The rubber fill was rubbing on the engine making the vibrating sound I was hearing. Good thing I caught this when I did. Again, thanks to everyone helping me out.
Old Feb 4, 2016 | 06:41 AM
I'm thinking this is an SRT6 thing imposed by the extra load and shocks caused by the S/C clutch engaging.
Haven't seen much about this failure on NA's ......
Old Feb 4, 2016 | 05:31 PM
boostmonkey's Avatar
Default
That harmonic balancer is DRT ("dead raight thare").
The supercharger places significant additional load on this pulley. It takes roughly 50 HP to drive the supercharger at redline on a stock car. A stacked pulley car uses 100+ HP to drive the supercharger. That is a lot of load on the belt and harmonic balancer.
HarleyBaby
Nov 28, 2015 08:25 PM
CharlieO
Nov 25, 2015 09:23 PM
ozkancab
Nov 19, 2015 02:40 PM
Morphh
Oct 26, 2015 03:03 PM
Morphh
Oct 26, 2015 10:50 AM
