Ported the Y-pipe
Old Feb 10, 2016 | 05:10 PM
chuK_138's Avatar
Default Ported the Y-pipe
Spent some time cleaning up a spare I got from rmcdaniel instead of the usual route. Rather pleased with the results!
File Type: jpeg
Old Feb 10, 2016 | 05:18 PM
chuK_138's Avatar
Default Re: Ported the Y-pipe
More pics of the inside before and after...
File Type: jpeg
Old Feb 10, 2016 | 05:22 PM
chuK_138's Avatar
Okay, my phone is only uploading one pic at a time. I'll try again.
File Type: jpeg
Old Feb 10, 2016 | 06:30 PM
Squirrel Crusher's Avatar
Now get it tefloned inside and your work will be worth while. Squirrel Crusher
Old Feb 10, 2016 | 06:36 PM
chuK_138's Avatar
It is Teflon coated, just not black like NW. Couldn't post the pics together and didn't feel like replying 7 more times to show it. Posting by phone is a PITA.
Old Feb 11, 2016 | 12:19 AM
4drturbo's Avatar
Wait and post on a PC. Looks great!
Old Feb 11, 2016 | 09:56 AM
Dementors's Avatar
Looks good.
Old Feb 12, 2016 | 06:58 PM
Sweet2002's Avatar
CHUK, Have you installed the big dog intakes yet? it sure would seem the ported "Y" and increased intake flow should some decent power. Did you do the "Y" with a dremmel type tool or do you have access to a machine shop? The tweaked intakes seem like they should also add some power but it seems not that many of the guys here have that mod. Even a drop in psi should happen with the better flow and if that is the case I would think the additional flow again should net more power than I have seen. So if the big intakes are not installed are you getting them on soon? Dyno results would be interesting as you would be meticulous about getting the best from these post SC mods, look forward to what you are able to extract! Sweet
Old Feb 13, 2016 | 09:29 PM
chuK_138's Avatar
Manifolds have been on for about a month now. Just put on the Y-pipe today but not doing anything else until the Zt-2 gets here. Once it's all been installed I'll verify where the AFRs are. It may see some rollers soon after.
Old Feb 13, 2016 | 09:58 PM
chuK_138's Avatar
Here's a link to the video. Much easier than posting pictures.
Old Feb 13, 2016 | 11:04 PM
JEFASOLD's Avatar
Originally Posted by Sweet2002
CHUK, Have you installed the big dog intakes yet? it sure would seem the ported "Y" and increased intake flow should some decent power. Did you do the "Y" with a dremmel type tool or do you have access to a machine shop? The tweaked intakes seem like they should also add some power but it seems not that many of the guys here have that mod. Even a drop in psi should happen with the better flow and if that is the case I would think the additional flow again should net more power than I have seen. So if the big intakes are not installed are you getting them on soon? Dyno results would be interesting as you would be meticulous about getting the best from these post SC mods, look forward to what you are able to ro! Sweet
Understand that the limiting factors here aren't all about manifolds and intake size and header size, we don't have the room for equal length headers and our valve size is limited due to only having 195 cu. in. That's why the SCAI is just about as effective as the DCAI but not as pretty. You can only stuff so much air/fuel in there and still get it out without changing the CAMS and then you have to deal with rough idling and peaky engine performance. Also, you don't want to sacrifice reliability.
Old Feb 14, 2016 | 10:32 AM
boostmonkey's Avatar
Default
Video Link: http://youtu.be/ueviYLaoe5g
It loads faster too. Pictures take forever to load using the IB Autogroup app.
Old Feb 14, 2016 | 11:25 AM
chuK_138's Avatar
I have time slips and a twin to my car with a single that proves the DCAI is worth the money and boost increase. It's all fun and games to theorize, but we actually tested this at the track and the dual always comes out on top. And it's the only mod difference between both engines.
getshawty
Dec 1, 2020 08:03 PM
pioneer4x4
Apr 8, 2016 10:15 AM
232MikeSC
Nov 25, 2015 06:55 PM
SeanOldaker
Oct 25, 2015 05:54 PM
chourse
May 19, 2006 11:02 AM
