Zeitronix IAT sensor question
Old Feb 20, 2016 | 07:40 PM
chuK_138's Avatar
Default Zeitronix IAT sensor question
Probably a stretch to ask, but is there a way to tap into our IAT sensor to feed the output to a Zt-2? Noticed that our stock sensor has a simple connection with two wires. Their sensor uses two wires. I don't have a problem buying their sensor. Just wouldn't want to make an extra hole in any of the components to mount it. Any help would be appreciated. I tend to stay away from wiring.
Old Feb 21, 2016 | 08:23 AM
Default Re: Zeitronix IAT sensor question
I see you didn't get an answer. I added bungs when I installed mine. It been a long time ago. When temps get a little warmer I am tearing into mine to do the rear end gear, I will be going over all that again. Getting more familiar with the zeitronix again. Haven't used in it a couple of yrs. I'll share all that with you then. I never did figure out how to set the parameters for the fuel pressure gauge. So I have to brush up too.
Old Feb 21, 2016 | 10:28 AM
chuK_138's Avatar
Thanks for the response doc. My main goal is to log as much data as possible through the Zt-2. Don't see the point of buying such a tool and only using it to log boost and AFR. Then again, I don't want to spend extra $$$ for sensors if I can tap into existing ones already on the car. Boost, IAT, and fuel pressure are the ones I'm concerned with after the ever important AFR. My friend has a welder and a nice shop to take care of the O2 bung install.
Old Feb 21, 2016 | 11:24 AM
Adding mine to the Y-pipe...
Old Feb 21, 2016 | 12:55 PM
chuK_138's Avatar
That's where our stock one is located. Plus it's a cast aluminum pipe with fairly thin walls. I was thinking it would just be easier to tap the wires from the stock sensor since it's easily accessible.
Old Feb 29, 2016 | 09:07 PM
chuK_138's Avatar
Hopefully I'm reading the schematics properly and Zeitronix's website correctly. Their IAT sensor is a two-wire sensor, our OEM is also. They have a signal wire and ground, so does the OEM. It looks like I tap the YL/DG (yellow, dark green?) wire for signal and BR/YL (brown, yellow) for the ground. The yellow/green wire should hook up to the Zt-2's white/brown wire for User2 input (which can be renamed), and the brown/yellow wire will go to the brown wire for a ground on the box. Other than that, everything else is hooked up and I'm pleased with it.
Old Mar 1, 2016 | 04:15 PM
Chuk I read IAT,,eng temp, throttle pos, mph, timming,left and right afr, Boost, fuel pressure and a few others i can't remember right now all set up by Rob and Rudy ask rob (needswings), how to set it up..jim
Old Mar 1, 2016 | 07:19 PM
chuK_138's Avatar
Jim, I can read everything else through the OBDII port, but I'd rather see it on the display. Not the easiest thing to stare at a laptop in the passenger seat while you're trying to control the car. It's either IAT or fuel pressure, and fuel pressure parts will cost an $75 or so. Getting my IAT should be free of extra expenses. Shame the Zeitronix display won't let you replace the EGT reading for something else.
Old Mar 1, 2016 | 11:32 PM
Chuk, take a look at my zeitronix pause it and you can see all the readings i have ,, this was a few years ago without the 2nd afr and the fuel . you will see that i have 12 slots but at this time i was only using 10 also the batt and map is not needed, which allows me 4 places to add what ever i want. I will be adding transmission temp this year and maybe oil temp.
HDV_0050_zps571f19eb.mp4 Video by amx1397 | Photobucket
Old Mar 1, 2016 | 11:38 PM
chuK_138's Avatar
You have the fancy DashdaqXL, I have the Zeitronix LCD display. Only 3 readouts available to choose on it. The EGT readout is dedicated to K type probes.
File Type: jpeg
Old Mar 2, 2016 | 08:34 AM
Now it is clear,, and I also remember i had one like that ,, I got off a member here,, sold it to a Merdedes guy, Maybe Rob would help you upgrade. jim
Old Mar 3, 2016 | 06:19 PM
I have the dashdaq/Zt-2...Chuk.
Fuya
15
May 15, 2017 11:09 AM
12345
Feb 29, 2016 03:33 PM
crossfire lover
Feb 19, 2016 04:15 PM
WindRestrictor
Feb 17, 2016 05:06 PM
Padgett
Feb 3, 2016 10:39 AM
