Interior liftgate removal
Old May 14, 2016 | 06:25 PM
BibaResto's Avatar
Default Interior liftgate removal
Best I can find are threads that start, "After I removed the liftgate's interior panels..."
What concerns me is that it only makes sense that the pull-down handle is fairly well attached since the rest seems pretty flimsy.
I only want to remove the lower (with liftgate down) panel but if the drill is to start at the upper brakelight end, fine.
But I just need to get it off without anything breaking.
Old May 14, 2016 | 06:56 PM
BibaResto's Avatar
Default Re: Interior liftgate removal
Okay, I found the screw behind the little panel in the center of the pull handle. My excuse is that I can see up close if I can look through my bifocals. Trifocals would be nice to have at times like this.
Old Aug 12, 2017 | 09:28 PM
Eisenhorn90's Avatar
Can you explain to me what I need to do after removing that screw?
Old Aug 13, 2017 | 08:20 AM
You then use a trim tool to pry under the panel, it is obvious in which order they come off. The bottom panel comes off first.
2004_
May 17, 2016 06:14 AM
Bayukbros
May 6, 2016 10:52 AM
BEATv1
Detail Shop
May 4, 2016 09:05 PM
technolteacher
Apr 28, 2016 11:02 PM
tillthewheelsfalloff
Apr 17, 2016 01:50 AM
