SRT6 dies; BAS ESP light when accelerating
Old May 30, 2016 | 10:41 PM
IsaacF's Avatar
Default SRT6 dies; BAS ESP light when accelerating
Hello,
A few days ago, I was driving my SRT6 home from work and when I pressed down on the accelerator, the car pulled for a few seconds then the engine just died: absolutely no throttle response whatsoever. The gauges and radio were still on and the BAS ESP light was illuminated when I looked at the dash cluster. Panicking, I pulled the car over into the nearest driveway and popped the hood and checked if something disastrous had happened. Everything looked fine. I put it in park, turned it off, then turned it back on. No BAS ESP light was illuminated and I drove it home cautiously, but with no issues. Later that day, I tried to recreate the issue... and I did. When I put my foot into the throttle, the car did the exact same thing I mentioned earlier. Upon further inspection of the engine, the boot for my Needswings DCAI had slipped off the throttle body at the top rear of the engine. I have no idea how long it had been loose. Thinking that was the issue, I hastily fixed it and took it out for another drive... nope, the same problem persisted. I have also noticed the car shakes and rumbles noticeably when accelerating hard, just before the engine cuts out: it kind of feels like a rumbly V8 under the hood instead of the smooth V6 I'm used to hearing. The BAS ESP light is never on unless this happens. I took it to Advance and had them read any codes, but they said the car is code free.
What could the issue be? I emailed Rob and he suspected the throttle body or the gas pedal could be at fault. Other research has lead me to believe a MAP sensor or an ABS module is to blame.
Thanks for any info you guys can provide!
Old May 30, 2016 | 10:47 PM
IsaacF's Avatar
Default Re: SRT6 dies; BAS ESP light when accelerating
To clarify, this issue occurs when flooring the accelerator; there is no obvious issue when driving conservatively.
Old May 31, 2016 | 05:37 PM
latemodel21's Avatar
I have seen this (BAS ESP light and limp to stop)happen with comprised connections at the throttlebody. Some times with codes, sometimes not. I have normally seen codes when the pedal goes out of limit.
Chris
Old May 31, 2016 | 08:35 PM
chuK_138's Avatar
Happened to me at the track.....longest 1/4 mile of my life!!! I wasn't out 30 ft when it happened. Had to roll the rest of the way and park in the grass under a light pole.
Old Jun 1, 2016 | 12:15 AM
IsaacF's Avatar
Chris
So the throttlebody itself may not be bad, but just some connections?
Old Jun 1, 2016 | 12:17 AM
IsaacF's Avatar
Did this just happen one time? What ended up being the diagnosis and what did you do to fix it?
Old Jun 1, 2016 | 01:22 AM
This (bas esp and limp to stop) happened on both my sons SLK32 and my SL55 more than a few times. In both cases, the throttlebody was not bad, it was the connector on the harness plugging into it. Later mercedes models actually had a short (male/female) extender harness that came glued into the throttlebody (presumably to seal/immobilize the connection). You may get away with merely cleaning the connector with a good contact cleaner (part of the mercedes service procedure for the TB IIRC).
it would most often happen after some hard acceleration (on more than one ocassion, I had just passed a line of cars on a winding road then crapped out and I had to roll to a stop looking like a D-bag).
On both cars, I tried cleaning the connectors and they would eventually fail again.
On my sons SLK32, I replaced the harness from from the ECU to the TB and the problem went away.
On my SL55, I added the male/female extender harness and the problem went away. (I was actually using it as a troubleshooting step as I expected the problem to persist and I could isolate it to either the harness connector or the TB .... but the problem went away and I left the extender harness in place)
I have the part number for the extender harness somewhere ($50 IIRC) and I also have part numbers for the housing and pins for a DIY re-connectorization ($12 or so I think)
hope that helps,
Chris
Old Jun 1, 2016 | 08:55 AM
IsaacF's Avatar
hope that helps,
Chris
Thanks for the info! I was curious to know if you had a part number/price for that ECU to TB harness. I think I should try that first since it cured the SLK32 of the problem.
Old Jun 1, 2016 | 10:32 AM
unfortunately, there is no number for that bit of harness that I put on the SLK32 as it is not available new. I removed it from a donor car with less than 12k miles.
the part number for the extender harness (MBZ description is "ignition cable") is 1131500028
and the best price now (including free shipping) is $66.75 from oediscountparts
https://www.oediscountparts.com/part...&siteid=215242
the descriptions for the plug housing and pins (pins come with a length of wire attached in various wire gauges ... 2 different gauges are used in this application) are a little vague. SO I bought an assortment. I will look them over and create a list for a DIY plug replacement if anyone is interested.
Cheers,
Chris
Old Jun 2, 2016 | 12:18 PM
IsaacF's Avatar
Cheers,
Chris
Thanks, man. I ordered the part and I'll give it a try. I'll let you know if it works.
mhajek18
Sep 11, 2015 02:28 AM
xfireon20z
Apr 5, 2013 09:26 PM
SoftballJunnkie
Mar 30, 2010 11:12 PM
onehundred80
Mar 3, 2009 12:43 PM
SACETORNC
24
Dec 27, 2008 01:15 AM
