What is this?
Old Jun 23, 2016 | 07:25 PM
pjs626's Avatar
Default What is this?
I am cleaning up rust from an apparent leaky battery from previous owner/s. When I removed the battery tray there is a white tubing coming out of a black rubber grommet of sorts from the fire wall . The pic shows the lower left corner. The tubing was not attached and rather brittle. I searched a few sites and to no avail a solution. There is also another tubing towards the center of the engine that also is not attached. Any one have any thoughts?
Old Jun 23, 2016 | 08:09 PM
JSK's Avatar
JSK
Default Re: What is this?
Vacuum line I think. Does it idle rough?
Old Jun 23, 2016 | 08:28 PM
pjs626's Avatar
No it was not idling rough
Old Jun 23, 2016 | 09:52 PM
chuK_138's Avatar
It's the vent tube that connected to the OEM battery. It connected to this weird little reservoir that let any fumes escape out of the engine bay.
Old Jun 23, 2016 | 10:00 PM
pjs626's Avatar
Escape out of the engine bay through the firewall? I guess I do not need to worry about it?
Old Jun 23, 2016 | 10:05 PM
chuK_138's Avatar
The tube keeps going down to the bottom of the car.
Old Jun 23, 2016 | 11:27 PM
Do not believe all you are told, so have a look at this post and see if it matches your car. I think it does.
CLICK
This is the thread the post came from.
CLICK
Old Jun 24, 2016 | 03:25 AM
chuK_138's Avatar
Took the battery out of the Limited to check my previous statement....and I was very much mistaken. You lost so much tubing to the acid! The link onehundred80 provided shows where the other end of that tubing should be. I suggest you get enough tubing to redo the whole line from firewall to the manifold from the looks of all the cracking.
ATX SRT-6
Jun 23, 2016 01:25 PM
39lasalle
Jun 17, 2016 05:03 PM
WindRestrictor
Jun 16, 2016 10:58 PM
Buggin
Jun 8, 2016 03:24 PM
dedwards0323
Car Shows
May 25, 2016 08:40 PM
