air housing boots
I was looking to fix a valve cover leak on my wifes SRT6, and I got as far as getting the air box pulled from the engine. Is there a trick to getting the rubber boot off that goes between the air box and the y pipe? It's factory clamped on on the air box side, and where it slips over the y pipe it almost appears to be glued. It might just be old, but I don't want to be buying a new one either.
I ended up just leaving it in one piece. I saw that more than a few people had broken the breather bolts of of the valve cove. Those don't need to be too tigh. I believe they are just there to hold it on when being assembled , as the valve cover bolts hold it down. I did end up just putting a very thin skim of rtv on the valve cover gasket where it contacts the head. I've resealed countless "ribbed" valve cover gaskets and I've found they're the worst.
BisB
24
Mar 14, 2016 10:44 AM
user 76087293
Mar 2, 2016 02:43 PM
Doc
Jul 7, 2004 01:46 AM
