Finally photos of my IC replacement
Old Sep 22, 2016 | 08:47 PM
waldig's Avatar
Talking Finally photos of my IC replacement
Ill add more and write up the IC replacement on my srt-6 2005. Original IC was well gunked up with antifreeze and such.
IC came from Needswings in a box with gasket gun and factory gaskets and coated IC of the RUDY design, well put together kit, no issues or problems. IC looked like nasa parts, nice.
DO NOT DO THIS unless your a gear head as it is complex and there are many ways to screw up- you need immediate memory and my hint, TAKE PHOTOS BEFORE YOU START FROM ALL SIDES, youll thank me later. TAKE PHOTOS AS YOU GO< same story here.
Enjoy and look thru the shots, WDY
Replacing intercooler w Needswings coated IC Taa daa by waldig | CrossfireForum
Old Sep 25, 2016 | 11:01 AM
Buggin's Avatar
Default Re: Finally photos of my IC replacement
Woody, what is that reflected plastic bubble wrap rated at? I bought a roll and decided it wasn't robust enough for that location. I ended up using it to make custom sunshades I found a fiber fill reflective material that was fire retardant to use instead.
Old Sep 25, 2016 | 04:34 PM
waldig's Avatar
Talking Re: Finally photos of my IC replacement
Its mylar insulation wrap, sure its good for 212 and I dont see any issue. Autocrossed the heck out of it and no smell or issues. Ill have to light some to see how it does but its mylar and that seems good to me Enjoy. ww
Old Sep 26, 2016 | 09:35 AM
Morphh's Avatar
U notice difference in IAT ?
Old Sep 26, 2016 | 09:53 AM
05srtsix's Avatar
Very nice, I will probably have to do this soon. Thanks for the pics!
The new IC core looks slightly smaller than the factory.
Any difference according to the butt dyno after IC/porting?
Old Sep 26, 2016 | 05:03 PM
waldig's Avatar
butt is much better but the IC is clean and it is same size though it appears to be a bit bigger in spots. Photo shows two ICs are NOT lined up so look closer, please.
Enjoy Woody
KnappAttack
Oct 29, 2016 08:29 AM
okeefe1961
Aug 29, 2016 01:46 PM
GraphiteGhost
Aug 10, 2016 08:54 AM
HOT FIYA
Jul 30, 2016 02:15 PM
Raicerx
Jul 6, 2016 04:47 PM
