What do you guys think of Royal Purple ATF?
Old 12-28-2016, 01:56 PM
Scalawag's Avatar
Default What do you guys think of Royal Purple ATF?
I know for many things Royal Purple makes a great product. It SAYS that it is good for our transmissions, but I want you opinions. The reason I ask is because it lists many different makes and models that it works for. If is so vestal, is it as good as factory for ours?
Max ATF is recommended for vehicles that require any of the following ATF fluids:Allison C-4, TES-295Mazda ATF-M III, ATF-MVAudi G-052-162, G-052-990, G-055-025Mercedes Benz 236.1, 236.2, 236.3, 236.5,
236.6, 236.7, 236.9, 236.10, 236.11BMW 7045E, LA2634, LT71141Chrysler ATF+, ATF+2, ATF+3, ATF+4Mitsubishi SP-II, SP-IIIChrysler Mopar AS68RCNissan 402, Matic-D, Matic-J, Matic-KFord FNR5, MERCONŽ, MERCONŽ VShell 3403, LA2634GM DEXRONŽ, DEXRONŽ II, DEXRONŽ IID,
DEXRONŽ IIE, DEXRONŽ-IIIF,
DEXRONŽ IIIG, DEXRONŽ-IIIHSubaru ATF, ATF-HPSuzuki 3314, 3317Texaco ETL-7045E, ETL-8072B, N402Esso LT 71141Toyota T-III, T-IVHonda ATF-Z1 (except in CVT’s)Voith 55.6335.XX (G607)Hyundai SP-II, SP-IIIVolvo Pass Car (4-6 Speed AT), 97340
(Construction Equipment), 97341JWS 3309, JWS 3314, JWS 3317Kia Red-1, SP-II, SP-IIIVW G-052-162, G-052-990, G-055-025Idemitsu K17ZF TE-ML, 03D, 04D, 05L, 09, 11B, 14A,
16L, 17C, TE-ML 14BJASO 1-AMAN 339F, 339 V1,339 V2, 339 Z1, 33
Old 12-28-2016, 03:26 PM
philosophico's Avatar
Default Re: What do you guys think of Royal Purple ATF?
Some guys swear to go only by what the OEM says to use and to some extent a agree. However if the brand your thinking about using meets the standards per the OEM than it should be fine.
Old 12-28-2016, 05:50 PM
When it comes to ATF fluid I always return to this post by Rudy. CLICK
But do what you want, your car and it could become your problem.
Old 12-29-2016, 11:21 PM
Scalawag's Avatar
Did a little more research and found this.
MB 236.1 - Automatic transmission fluids (ATF, Specification 236.1) - Mercedes-Benz Specifications for Operating Fluids
