Looking for like minded - Logged Fuel Flows...Dasdaq/TorqurPro...
Old Jun 5, 2017 | 05:08 AM
Billy22Bob's Avatar
Default Looking for like minded - Logged Fuel Flows...Dasdaq/TorqurPro...
I'm wondering what others are getting for their peak fuel flow at WOT.
The following was back in 2014 with only the C3 65mm +stock injectors/pump/pressure at 800ft above SL and 10C/50F.
This data was via the TorquePro app.
*The mani pressure from that has 14.7psi subtracted from it to give Psi gauge.
PS - changing the AFR (guess) only changes the Air figure...not the cc/min/inj
Summary for this case
M....333cc/min/inj
N....120L/hr
P....31.7USGal/hr
Mani Press =16.5psig
Old Jun 5, 2017 | 07:06 AM
daveesrt6's Avatar
Default Re: Looking for like minded - Logged Fuel Flows...Dasdaq/TorqurPro...
I use dashcommand but i am sure i have seen 140lph , my max revs are 6240,
I will try and check it out tomorrow.
Old Jun 20, 2017 | 05:28 AM
daveesrt6's Avatar
Dascommand reports 114lph , lt fuel trims negative to 5.4 .
my altitude here is 1240m (4400ft)
It goes harder at sea level ,next time i am down there i will note the reports.
Old Jun 20, 2017 | 08:23 AM
tunaglove's Avatar
Can you post your long term fuel trims please?
