supercharger whine
Old Dec 13, 2017 | 08:33 PM
blackpepper's Avatar
Default supercharger whine
I replaced a leaking intercooler two few days ago now I get a supercharger whine on startup an shutting the car off like the supercharger is engaged definitely hearing it more now going to double check my hoses and lines cars idles and run great no cel lights also did tje bake potato mod on the intercooler IATs are still 20 to 25 above ambient
Old Dec 13, 2017 | 11:33 PM
Squirrel Crusher's Avatar
Default Re: supercharger whine
Have you rechecked your superchargers oil level after reinstalling it? NeedsWings sells the Jet Turbine oil you need. Normally you change the oil until every 100,000 miles. If the serpentine belt is off by one groove on any of the pulley's,you'll hear it. Squirrel Crusher
Old Dec 14, 2017 | 07:45 AM
waldig's Avatar
Talking Re: supercharger whine
Clean intercooler makes it louder, Woody
IAT seem higher, is the IC clear of bubbles?
Old Dec 14, 2017 | 04:10 PM
dinasrt's Avatar
Not positive, but doesn't Chill Charger(water wetter)additive help with breaking down the little microscopic air bubbles, in addition to the other good things it does with the IC coolant?
Old Dec 15, 2017 | 12:10 AM
my normal IATs were upper 20s to 30 degrees above ambient but now lower 20s system separated but that was with distilled water draining that an going with hyercool or water wetter,also I do have a aftermarket heat exheater definitely larger than stock I am resding my IATs from a torque app pro so I am guessing the temps are reading what the factory sensor is reading
Old Dec 15, 2017 | 07:59 AM
waldig's Avatar
I wrote up an article about using a thinner antifreeze mixture for the IC to improve the heat transfer. Pure water is better than antifreeze, it only used for freezing temps and corrosiion. I used 20% antifreeze and water pump treatment to keep the chemistry happy, Enjoy Woody.
Old Dec 15, 2017 | 11:00 AM
The SC should not operate unless the magnet is energized although it will free wheel due to the air passing through it.
Could it be the air pump that is heard and not the SC? Maybe the air pump is operating all the time.
Old Dec 18, 2017 | 09:08 AM
Intercooler with baked potato mod appears to be wrking my IATs are 19 to 21 degrees above ambient according to my torque pro app could be wrong its using the factory sensor also supercharger definitely louder got a video posted an I picked up 2 mph so I got my performance back an some extra cooling oh ymy normal IATs use to hover around 30 to 35 above ambient,my system is separated ford lightning intercooler pump,aftermarket very large heat exchanger and now the back potato mod so far so good
Old Dec 18, 2017 | 11:07 AM
This post was originally about the SC whine at start up and shut down, what happened?
bbsrt6
Dec 22, 2017 05:19 PM
Musclefan21
Mar 8, 2010 11:25 PM
persicutor
May 22, 2009 11:03 AM
simon-srt6
Jun 4, 2007 09:34 AM
intenseblu
Oct 7, 2006 12:47 AM
