No start issue
Old May 29, 2018 | 08:20 PM
blackpepper's Avatar
Default No start issue
Got my tcu back from getting tuned reinstall it wow car dont start ,battery voltage good tried jumping still nothing everthing works but no click from the starter or nothing pulled my relay looks fine but going to resolder the 6 pins an see what happens
Old May 29, 2018 | 09:02 PM
Default Re: No start issue
Well guys I solved my problem somewhat just email eurocharged think my tcu is fried I unplugged the tcu car start up no issue turn car off plug in tcu no start i knew sonething was wrong when nothing but a black box was indicated when it should have said P for park
Old May 30, 2018 | 02:27 PM
Spoke with eurocharged this morning very polite and helpful said they will reflash the tcu again I asked since I had a speedriven tcu would that effect there tune guess I will wait a few more days to enjoy a fully eurocharged tuned 62mm beast
Old Jun 5, 2018 | 10:07 PM
I seriously regret doing a gear swap now since vendor X gave me a e55 tcu an eurocharged is having a time trying to get it too work
Old Jun 5, 2018 | 10:20 PM
if you don't get this solved in the next few days or so let me see what i can do. i have a new guy that says he can flash the tcu, I will try to get a tcu (stock) one and have it flashed to the 3.27.
your time line may not work with me but we can try,,first i have to get a tcu then get it flashed then send it to you i am looking at about 3 weeks. hope the new erocharging will work. jim
Old Jun 6, 2018 | 06:35 AM
Thanks I will do I did order a 2007 tcu last night from ebay last resort but it still crazy how I ended up with a e55 tcu in my car that did wek but not now but I am patient an got my fingers crossed today thanks again I may have to take you up on that offer.The tcu from 2007 should wrk anywrk since Ingpt a differential from a 2007 limited
Old Jun 6, 2018 | 08:07 AM
no it will not. unless it is the correct P/N,,, it has to be a tcu from a srt 6 or a c32 or slk32 I will look for the p/n ,,if i can find it I moved and now can't find anything jim
Old Jun 6, 2018 | 10:17 AM
I would suspect that when you add two different vendor tunes to a TCU that was not meant for the car you should expect some trouble.
Old Jun 6, 2018 | 10:23 AM
you may be right , I have always had Rudy flash mine . but there is a part number for the tcu that you have to use ,one for the srt and a different one for the limited.
Old Jun 6, 2018 | 11:10 AM
with the correct P/N you can get it tuned any way you want and it will work. just make sure the p/n is the same when you get it back. jim
Old Jun 8, 2018 | 01:25 PM
Thanks Jim eurocharged Tcu is arriving today and the limited tcu is arriving also I will have that tcu tuned as well at a later date .
Old Jun 8, 2018 | 04:04 PM
sorry the limited will not work in the srt tuned or stock you have to get a srt6 tcu and then tune it to the 3.27 that is the only way it works. jim
Old Jun 27, 2018 | 05:31 PM
and the saga continues still have exploted my 3.27 swapped srt6 dam
BltByKrmn
274
Jun 2, 2014 06:01 PM
X-Feuer
Jun 30, 2012 03:47 PM
srtswizz
Nov 17, 2010 04:49 PM
speedman
Sep 9, 2008 06:55 AM
Extensive
Oct 18, 2007 04:55 PM
