Day at the Drag Strip
Old May 2, 2005 | 09:18 AM
SRT6_Roadster's Avatar
Default Day at the Drag Strip
Took the beast out to the drag strip on Sunday. Very happy with my improvement over my last trip out. I was consistently able to run 13.0 at 108-109. With more practice (or better yet more traction) and depending on track and weather conditions I think 12.8 is very achievable with a stock car. I was hitting my 13.0 with 2.0 60' times.
Old May 2, 2005 | 12:21 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Day at the Drag Strip
wow...those are great times, especially with a roadster...great driving!
Old May 10, 2005 | 02:25 PM
pipes's Avatar
With that mile/hour - you should be able to get a low 12 or high 11 if you had optimum traction. Are you using slicks?
Old May 10, 2005 | 09:12 PM
former NXMX5's Avatar
high 11s at 108-109? i think thats a bit optimistic. im wondering about the slicks too. maybe get yourself a pair of BFG drag radials, and go with about 15# of air...
great runs BTW... great 60' times --
Old May 10, 2005 | 09:20 PM
Those numbers are on worn stock tires. It is getting close to time to replace them.
Anywhere in the 11's is very optimistic. I think with more practice 12.8 is very possible, given ideal conditions maybe 12.6's.
My first trip to the Drag's I had one run with a 1.7 60' time. The ET & Trap speed were slower than my posted times though.
Drag Radials would make a big difference.
Old May 11, 2005 | 01:53 PM
actually drag radials might be worthless if the ESP program kicks in when you try to do your burnout. what exactly does turning the system "off" do?
Old May 11, 2005 | 08:27 PM
Aero Blue's Avatar
Thumbs up Re: Day at the Drag Strip
I used to own a very modified Grand National and my best time was 12.68 @109 mph w/ 1.91 60 ft time. In my cars defense though, it did have 120K on the original motor/trans. In addition to that, the turbo was supposed to have a 3000 stall to make it perform at its best and I didn't have that or the new valve springs that it needed after 60K. IMO the 108-109 mph should get you into the mid 12's with BFG drag radials or Nitto drags. Even new tires aired down a bit (30-35 psi) should help. Make sure you turn off the T/C though as it retards the timing, but you probably already know that. One more thing, think Vanilla Ice and "ICE ICE BABY"!
Old May 12, 2005 | 05:23 PM
I have no clue what you mean by "your turbo was supposed to have a 3000 stall". I have not heard of a stall speed on a turbo. Do you mean it was supposed to spool up by 3000 rpm?
Turning of the ESP reduces the threshold at which it activates.
You can get a enough of a burnout to warm up drag slicks. You can generate huge clouds of smoke with your tires if you want.
Old May 12, 2005 | 06:19 PM
Aero Blue's Avatar
Arrow Re: Day at the Drag Strip
Sorry about the confusion, I didn't make the post clear. What I meant to say is the turbo I had (TE60) needed a 3000 stall to operate correctly. That turbo had a much larger wheel and the stock torque converter didn't stall high enough to take full advantage of the turbo. To go along with it (TE60) I had a front mounted intercooler, Terry Houston 3" downpipe, 42 lb injectors and a "dial a chip". I feel very embarrassed after re-reading my post!
Old May 12, 2005 | 07:03 PM
Bullseye's Avatar
Those are damn impressive times. I always said 12 second stock runs are possible. And i have seen cars on slicks run low 12's at slower trap speeds than 109.
I just went to the track this saturday. Bone stock and with a boost leak, was only holding 10-11lbs to redline. I ran 14.1@99 My 60's were at 2.2. You could definitely tell my leak was hitting me after the around the 8th and past it. As other stock srt-4's i could not keep up.
Some of our modded srt's in our club ran 12.59@110, he is a stage 2.
Then some of the bigger boys ran 12.40's at around 120 mph. NO traction owns the srt-4. Gotta love stage 3.
Old May 12, 2005 | 11:14 PM
andrew's Avatar
my M3 ran 1.9 60' times....a 1.7 is unbelievable.
click on multimedia once link is open...
https://www.crossfireforum.org/galle...cat/500/page/2
Old May 13, 2005 | 02:04 AM
Bullseye's Avatar
I also used to pull 1.9's with my mach 1, i did pull off a 1.97 on my 13.2 run but never got down to a 13.0. Nice driving.
franklindm
Mar 14, 2020 12:23 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
ozkancab
Sep 25, 2015 10:55 AM
Abaton6
Sep 24, 2015 10:14 PM
jaesa
Sep 7, 2015 01:50 PM
