Engine Performance Problem
Old Jun 22, 2018 | 04:06 PM
David M's Avatar
Default Engine Performance Problem
About half the time my engine has full horsepower, which is to say that it is producing its full 330 horsepower.
The other half of the time the engine is producing perhaps 30% to 40% of that horsepower. When it changes it is pretty much random. It can and does happen on the highway driving at normal speeds.
I have no idea what is causing this.
Could it be an Engine Control Module problem? A fuel pressure problem? Could the mass airflow sensor not be working? Could it be a vacuum leak?
My car is a 2005 convertible SRT6.
Thanks
Old Jun 22, 2018 | 05:06 PM
Sussudio's Avatar
Default Re: Engine Performance Problem
Thanks
Check the IC pump as it is a very common problem with the SRT 6. That would explain the intermittent power. There are threads on here explaining that specific problem. Search is your friend
Old Jun 22, 2018 | 08:40 PM
JSK's Avatar
JSK
Where do you live? I live in the Phoenix area and on occasions on really hot days the AIT is too high and the clutch won’t activate.
Old Jun 22, 2018 | 11:07 PM
Thanks
Here is the IC pump, this PDF shows how to install a Johnson pump, that is not in favor these days and you should use a new Bosch pump the last figures are 10.
CLICK
Old Jul 6, 2018 | 12:16 PM
David M's Avatar
I did a search. So if the intercooler pump is not working (to cool the air going through it) then the superchargers clutch will not engage the supercharger? The solution is a new pump? Do I have this right? Thank's.
Old Jul 6, 2018 | 01:25 PM
Raynger's Avatar
Problem: After driving until normal operating temperature (about 15-20 min), the Supercharger shuts down until I come to a complete stop, then it shuts down intermittently after that. There is no OBD scanner code being displayed to explain this problem.
I purchased an 05roadster srt-6 34,000mi in Nov. 2017. I had a Mercedes repair shop perform a thorough check and report any problems. At that time I was told the Intercooler motor was defective. I bought a new bosh Inter Cooler from Needs Wings web site and had it installed. It didn’t fix the above problem $350.00 including installation.
After following the threads on Crossfireforum there are multiple fixes explained from NeedsWings Air Intake Temperature sensor @27.95, Different I.C. pumps $120.00 and up, NeedsWings Intercooler Fluid Isolating Kit $59.95, NeedsWings Supercooler Radiator $449.95 , NeedsWings DEI Chill Charger fluid $10.95, NeedsWings Killer Chiller IC Kit $729.95.
None of the above includes installation.
It seems to me, to be a very expensive problem that no-one has the “exact” answer to.
Right now I’m thinking that the Air temp. is the problem with the ultimate fix being the Killer Chiller.
Old Jul 6, 2018 | 01:41 PM
David M's Avatar
I was hoping to avoid fixing the problem by quessing at and then installing parts which I may not have needed to replace in the first place because those parts already worked. That can get unnecessarily expensive.
Are there any other ideas? Thanks.
Old Jul 6, 2018 | 01:53 PM
Raynger's Avatar
I'm going to try the NeedsWings Intercooler Fluid Isolating Kit with the DEI Chill Charger. I'll reply the results.
Old Jul 6, 2018 | 01:55 PM
David M's Avatar
Are you having the same problem as I am?
Old Jul 6, 2018 | 03:00 PM
KDW4Him's Avatar
I just started with the same symptoms you describe. Especially on a 90 degree day. There is post after post of people saying at about 30K miles the OEM pump gives up and a new one is needed. I just turned 31K miles. Even though I am placing a $120 guess at it by getting a new pump the odds are still in my favor by all of the other SRT's who have needed pumps at 30K.
Old Jul 6, 2018 | 03:05 PM
KDW4Him's Avatar
Originally Posted by Raynger
After following the threads on Crossfireforum there are multiple fixes .........
If the pump isn't pumping enough fluid to cool or the sensor is reading incorrectly those would be straight replacements and a FIX for a problem. All the rest you mention are MODS to cool the intake even cooler than stock for more HP.
Old Jul 6, 2018 | 03:10 PM
KDW4Him's Avatar
I was hoping to avoid fixing the problem by guessing...
You can read the air temp live with an OBDII capable of reading it. See https://www.crossfireforum.org/forum...lant-temp.html
Old Jul 6, 2018 | 03:27 PM
David M's Avatar
Interesting! Looks like I need a new intercooler coolant pump. Is Bosch preferable? Best place to get one?
Old Jul 6, 2018 | 03:30 PM
KDW4Him's Avatar
Bosch 010 pump. Some use FCPeuro some use Needswings to get them.
Old Jul 6, 2018 | 03:37 PM
Raynger's Avatar
exact same problem
KDW4Him's Avatar
CLICK
Additionally I have read where some have used c-clamps or vise grips with something soft in the jaws to clamp the hoses off to keep fluid in while doing the change. I plan on trying that and will report how it goes. EDIT, this method works fine.
Ready to install the new pump
cardboard covered vice grips
only lost this much fluid
Old Jul 6, 2018 | 03:51 PM
David M's Avatar
Found it!
https://www.fcpeuro.com/products/mer...uEALw_wcB#desc
Old Jul 6, 2018 | 03:57 PM
KDW4Him's Avatar
Same part number on the one I am about to install.
Old Jul 6, 2018 | 05:15 PM
The 30,000 mile life span is news to me, they went bad after various miles. Many never got close to 30,000 as. Badly designed part caused the problems.
I replaced mine when I got the car rather than waiting for it to go.
Old Jul 6, 2018 | 08:59 PM
KDW4Him's Avatar
The pump is very easy to change, just completed the work and road test. All OK so far.
