Lights
Old Jul 25, 2018 | 11:02 AM
Burnley Miller's Avatar
Default Lights
When I stop the driving lights, tail lights and marker lights will not turn off. I am having to disconnect the battery. This started about a week ago. I need help
Old Jul 25, 2018 | 04:21 PM
Shamrock's Avatar
Default Re: Lights
How long do they stay on? The lights are supposed to come on wehn you stop and open the door. They stay on for a (minute or so?).
Old Jul 25, 2018 | 04:28 PM
Default Re: Lights
These lights are timed out by security module in the trunk, do you have water in use the passenger side well in the trunk?
Simply put have you had trouble with water getting into the trunk?
I see you have an SRT, they are fomous for water leaks, through a failed O-ring seal at the base of the spoiler mounts and by waypter getting passed the poor seal around the spoiler mounting.
Water in the well wrecks the security module causing it to operate poorly.
You can slide a taper of paper between the foam and the steel of the well and see if it gets wet.
Old Jul 25, 2018 | 09:19 PM
Default Re: Lights
The lights do not turn off until the battery is disconnected. I will check the trunk for leaks, I haven't noticed any in the past.
Thanks for the suggestion. The car was always kept in the garage until our house burned down December 16. It now sits outside the apartment until our house is rebuilt.
We bought the car in 2007.
XFGirl
Oct 21, 2024 07:16 AM
DrtyVegas
Sep 22, 2018 06:07 PM
Erichenderson02
Aug 4, 2012 12:15 AM
AmCross
Mar 27, 2012 09:49 PM
dwightdmagee
Jul 8, 2009 03:48 PM
