Smallest Rims that will Fit?
Old Aug 15, 2018 | 12:58 PM
Scalawag's Avatar
Question Smallest Rims that will Fit?
I'm looking to put some winter tires on my car and finding a matched set is much easier and cheaper. I know that 18" will fit all the way around. Will 17" or even 16" rims fit over the breaks and other suspension parts?
Old Aug 16, 2018 | 12:16 PM
David M's Avatar
Default Re: Smallest Rims that will Fit?
Are you trying to save money by going smaller? If not, I would consider going with four 18 inch steel rims that the seller guarantees will fit. You can get steel for significantly less than alloy wheels.
Also, your speedo will be off by a smaller margin.
Old Aug 16, 2018 | 02:20 PM
Padgett's Avatar
Well a set of Crossfire rims & tires fits on a Merc SLK320 and the SLK230, 320, and 280 were mostly sold with 16" alloys.
Old Aug 16, 2018 | 04:10 PM
DTMenace's Avatar
The 2004 SLK32 (AMG model) had stock 17" Aluminum wheels as standard equipment from the factory. The front brake rotors were larger (345 vs. the Crossfire 330), so the 17" wheel will work for the Crossfire, using a tire with a 55 or 60 sidewall size aspect.
Dennis
DTMenace
Old Aug 16, 2018 | 09:54 PM
Padgett's Avatar
Unfortunately the SLK32 was a very rare model (equivalent to SRT-6). However AFAIR a SLK320 and a Crossfire use the same front brake rotors so the '98-'04 SLK230/320 16' rims should fit.
OTOH the '04-'09 SLK350 came with 17s stock and the base SLK280 came with 16s. After '09 the SLKs went to a 14mm lug bolt.
Old Oct 22, 2018 | 01:09 PM
Scalawag's Avatar
Thanks everyone. I'm looking for used wheels that will fit with snow tires. 16" are pretty easy to find. 17" & 18" are seeming more difficult. I don't want to spend money on 16s and find out that they won't clear the breaks or something.
Padgett
Nov 23, 2013 10:58 AM
iCarfly
Jul 18, 2013 03:08 PM
crazass
Jan 23, 2007 09:48 AM
crazass
Jun 21, 2006 11:15 AM
JBsZ06
Jan 2, 2006 05:56 AM
