compression pressure
Old Sep 30, 2018 | 05:10 PM
Guran's Avatar
Default compression pressure
Hi
What is a normal healthy compression pressure in a M112 engine ?
Old Sep 30, 2018 | 06:45 PM
Default Re: compression pressure
Originally Posted by Guran
Hi
Per the engine specs in the Service Manual the SRT6 compression pressure is 689 kPa (100 psi).
Old Oct 1, 2018 | 03:06 PM
Guran's Avatar
It sounds extremely low. I think they mean 200 psi
Old Oct 1, 2018 | 03:21 PM
velociabstract's Avatar
I did a home compression test a few years ago. I got 149 psi warm with almost no variation between the cylinders. I cranked for 5 rotations each cylinder.
Les
Old Oct 1, 2018 | 03:24 PM
The car is supercharged, they have lower compression. I took the figures from the Service Manual, they have been wrong before. 🙄
Old Oct 1, 2018 | 07:22 PM
Guran's Avatar
I saw the values on the service manual to, and that cant be right. Supercharged engine has lower compression ratio, that is something people
Mix together. I do understand your thinking. Did it my self. Compression ratio and Compression pressure
Old Oct 1, 2018 | 07:46 PM
Guran's Avatar
Les
Thats a healty engine.
i have talked to mechanic on Mercedes, No one else knows. Its a riddle.
11 - 14 bar , 159,5 psi - 203 . psi . Very good engine. super
10 - 11 bar, 145 - 159,5. OK
9 bar, 130,5 psi. Bad engine. No pressure
Old Oct 1, 2018 | 09:43 PM
Good, bad or super I don't know. 11.9 at 117 mph = my 149 psi. 24,000 miles +o- (sea level) You can see what I've done to my car. It's real data, use it if it helps you.
Les
Old Oct 3, 2018 | 03:36 PM
Guran's Avatar
Les
Thank you Velociabstracy. Its real data i want. 11.9 is super
cdrance
21
Apr 1, 2016 08:40 PM
