Broken mounts?
Re: Broken mounts?
A sure way to test for broken engine mounts (most commonly the drivers side) is to open the hood, put the car in drive, press the brakes, and give it some throttle. The drivers side of the motor should rise some, if it comes up a lot, then you probably have at least one shot mount. It is recommended that you change all three at the same time.
The engine mounts are "real' fun the change
Doug Magill
11-22-2014 08:36 AM
