What should I look for
Old Apr 19, 2019 | 08:46 PM
YFD_322's Avatar
Default What should I look for
I'm looking at 2 SRT's right now, both 05's one with 50k for $13k and one with 29k for $14k. Still, have to have them checked out. Is there anything special to look for on these? Looks like there are a lot of problems with this model?
Old Apr 19, 2019 | 11:20 PM
philosophico's Avatar
Default Re: What should I look for
These cars are pretty much bulletproof. There is nothing major to look for that would cause the engine to fail or transmission to take a dump. Anything that might be a problem can be fixed for cheap (depending on price of part).
On a SRT-6, the main thing to look for at least with my experience is the intercooler pump going causing the blower to heat soak. You'll know if this is the case as you'll have power then bam, it will as if a parachute was pulled and you hit a brick wall as the car will just stop pulling. Other issue is the CPS (crank position sensor) they tend fo fail periodic but nothing major.
Old Apr 19, 2019 | 11:29 PM
YFD_322's Avatar
That's reassuring, thank you!
srt8guy
Apr 26, 2017 11:52 AM
12yan12eed
Sep 17, 2009 11:25 AM
redwolfb14
Jan 19, 2007 09:33 PM
FirebaseD
Jun 2, 2006 04:10 PM
David Burns
Mar 20, 2004 11:52 PM
