SRT-6 Hub cap
Old Jul 10, 2019 | 08:53 PM
Moparboy's Avatar
Angry SRT-6 Hub cap
Hi,
I left my car at the garage today to install new tires on my 2005 SRT-6 convertible.
I take care to ask at my appointment if the garage have the special tire machine that don't touch mag wheel. and they said yes. So go for it!
Result: Tire look great and run well.
I realise tonight at my home one hub cap is not installed properly.
After inspection of 4 wheels: the fu*** mechanic ruin all 4 hub caps by prying it and bend them. So now they don't fit properly and bend is apparent.
Stupid guy GRRRR!!!
Any idea were to find new ones or a place to repair them?
I joined pictures of cap.
Old Jul 10, 2019 | 08:59 PM
Default Re: SRT-6 Hub cap
what bends them is they don't line up the slot in the cap with the cut-out in the wheel and hammer them on anyway.
Old Jul 10, 2019 | 09:05 PM
Moparboy's Avatar
If i understand well, they have a precise position for installation? Hope it was just that!
OK i will try to remove them and reinstalling them tomorrow. Thank's !
Old Jul 10, 2019 | 10:22 PM
Yes, do so, but it won't help the bend they have already done to the locator tab portion
Old Jul 10, 2019 | 11:00 PM
unarel32's Avatar
Happened to me too.. They also lost my stock valve stem caps. I left a bad review.
Before I get tires installed now I remove the caps and valve stem caps so they can't screw them up.
Old Jul 11, 2019 | 08:23 AM
UrbanE's Avatar
A great quality wheel repair shop can pound these back into shape.
Ive had to have mine reworked for the same reason.
Watch ebay or call rob at needswings for replacements
prepare to open your wallet wide.
Thesebdont come up up very often. Take them off with plastic pry tools before your next trip to the tire or brake shop
Old Jul 15, 2019 | 09:34 PM
Moparboy's Avatar
Today i removed all hub caps. With care, i have succes to straighten them and reinstalling it. Like Ala_xfire mentionned previously, they are bend because mecanic guy don't pay attention to align them with the **** in the wheel.
Problem solved! Thank's for the trick!
Old Jul 15, 2019 | 10:37 PM
UrbanE's Avatar
I would love to see the end result
Please attach a few pictures when you get a chance
Old Jul 15, 2019 | 11:45 PM
Glad to help !
I think maybe we both have been aligned with the same **** at one time or another
Old Jul 16, 2019 | 07:48 AM
Whenever I have tire service performed, I also remove the center caps on all 4 wheels and leave them at home. No chance for them to look elsewhere in the car and attempt to re-install. Keeps the Service Shop from scarring up the wheel while prying the center cap off. I usually remove the center cap with a plastic pry stick (like from a set of interior panel tools) or use my driver's license to slide along the edge until I can pull the center cap off.
I also have a set of McGard wheel locks on my 2007 Coupe. I remove them & re-install the standard lug bolts so the Service Shop doesn't have to deal with them. When I get back home, I remove a lug bolt on each wheel and replace it with the locking bolt. And I always tell the Service Shop to torque the lug bolts to 80-85 ft-lbs. The spec is 81 ft-lbs on the Crossfire. Most shops will torque to 100-ft-lbs w/o looking at proper value for car.
Old Jul 16, 2019 | 12:37 PM
Idiot prevention, they are everywhere.
Old Jul 16, 2019 | 12:40 PM
They are breeding as well. 😜
Old May 5, 2021 | 05:02 PM
M SL 65's Avatar
It seems McGard only has the ball/radial not the cone shaped locking lug bolt. Did you use the McGard, Radius Seat Lock Bolt Set, product #28023?
TY
Rupert
Old May 5, 2021 | 07:17 PM
TY
Rupert
When I purchased the lock set for my 2007, that was the product number I bought. But I was retaining the OEM wheels. If you're mounting aftermarket wheels with cone seats, McGard makes a set of wheel lug bolt locks that will work. Take a look at these / They are only 0.6 mm longer than the Ball Seat version for the Crossfire wheel (should work): CLICK.
russthemuss
Apr 8, 2021 05:27 PM
Brian P
Jun 8, 2020 06:36 PM
zip439
Dec 6, 2019 03:53 PM
Ringmaster
Nov 20, 2018 06:00 PM
xfire17
May 7, 2014 04:30 PM
