cylinder number five
Old Nov 16, 2019 | 01:47 PM
Default cylinder number five
I have a misfire reading for cylinder number five. Is that the middle one on the passenger or driver side?
Old Nov 16, 2019 | 02:28 PM
Default Re: cylinder number five
The cylinder numbers are moulded into the valve cover castings.
This is outlined in the Service manual.
Thanks for asking.
Old Nov 16, 2019 | 03:44 PM
Thank you sir, do you know any trick for getting the plug wires to snap in place on the plugs? When I was younger it probably wouldn't have been an issue but my upper body strength isn't what it used to be.
Old Nov 17, 2019 | 10:19 AM
Toolman's Avatar
Using a very thin coat of dielectric grease will make it easier to push them on and take them off. You do not want to get any on the terminal inside the spark plug wire, or on the metal tip of the spark plug. A small amount that may rub on the tip of the spark plug while pushing on the boot will not be a problem.
Old Nov 17, 2019 | 05:31 PM
Toolman's Avatar
Old Nov 17, 2019 | 05:41 PM
It is probably best to put only a thin layer on the ceramic insulator of the plug.
Hurricane
Jun 26, 2017 09:47 AM
stevieb
Feb 2, 2017 08:08 PM
+fireamx
Jul 17, 2008 06:46 AM
SeaXfire
May 26, 2004 07:28 PM
krusty_the_klown
Apr 2, 2004 02:51 PM
