65mm Supercharger Pulley Failure
Old Mar 6, 2022 | 01:43 PM
fric8489's Avatar
Default 65mm Supercharger Pulley Failure
Last wednesday while driving home from work, i had the low coolant light come on i kept monitoring temp and tried to make it home. I got within 5 miles of home when temps started climbing pulled over shut engine off. Under hood there was coolant everywhere. It was dark out and couldn't really find the issue so cooled engine down and had towed home.
After refilling coolant 2 gallons of distilled water, i fired it up and easily found coolant spraying from hose on oil cooler. The aftermarket 65mm supercharger pulley from eurocharge broke and one of the pieces had cut two line and cut gash in hood insulation.
I put the stock pulley back on and found similar hose at autozone to use until i can order the correct oil cooler coolant line. Still working on getting air out of the system and need to figure out if running the ic pump dry caused any issues with that pump but other than that the car is back up and running. Saw some interesting temp swings while getting air out of the system.
I have been daily driving car for about 7 months now. The pulley is 7 years old with 14,000 miles on it. Prior to this year, i had only driven on weekend or a friday.
I am going to order proper parts to repair it completely once i figure out what the part numbers are. Here are some photos.
Old Mar 6, 2022 | 03:36 PM
philosophico's Avatar
Default Re: 65mm Supercharger Pulley Failure
The Eurocharge pulley failing is normal at this point. Its not a matter of if but when. You need to get a scatter-shield. If you had one, you wouldn't have shredded your coolant line or damaged the oil cooler. When my eurcocharged 65 pulley failled it broke just like that. The only difference is, I was actually removing the pulley for some reason and when I went to pull it off it was split in half. I put my stock pulley back on and went the 178 crank pulley route.
Old Mar 6, 2022 | 03:46 PM
NeedsWings's Avatar
i think i have everything you will need in stock, PM me your email address and zip code.
vaboca
Oct 16, 2021 01:18 PM
AlbertFattal
Sep 24, 2018 05:42 PM
maznonno
80
Nov 28, 2016 11:11 PM
austinbarrylee
Jul 20, 2016 03:48 PM
srtmodder
Jun 6, 2016 04:20 PM
