New SRT6
Old Apr 7, 2022 | 08:57 PM
Nutrix's Avatar
Default New SRT6
Hi guys. I just bought a SRT6 and it has the DCAI from Needs Wings. Can anyone tell me if there are any other engine mods or how I can tell if there has been a tune done. Also what parts from needs wings are installed? Thanks for any help or info.
Throttle body upgrade?
Old Apr 7, 2022 | 09:04 PM
philosophico's Avatar
Default Re: New SRT6
I dont know why but your photos don't show up clear to me. I doubt there is bigger TB on your car as that mod came out just a year or 2 ago and its not one that most do. Only the hardcore racers would do that mod. As far as a tune you wont be able to tell but if the blower pulley has been swapped then I'd believe there would be a tune to go with it. Go to needswings.com and look at the mods available for the srt6 and see if anything looks like it might be on your car.
Old Apr 8, 2022 | 07:42 AM
bluecoupe's Avatar
I see a NW SC coolant isolation kit. You'll need to pull the plastic cover to check for pulleys.
Old Apr 8, 2022 | 09:29 AM
DTMenace's Avatar
Nutrix
Welcome to the SRT6 family of owners on the Crossfire Forum. The link below contains the database for all of the SRT6's we've found since 2007. Please provide the last 5 numbers of your VIN#, color and whether it's a coupe or roadster.
Enjoy your Crossfire SRT6....
Dennis
DTMenace
SRT6 Serial Numbers ~ PDF format file...continued - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Apr 8, 2022 | 04:30 PM
Nutrix's Avatar
thanks. I’ve added the pulley pic.
Old Apr 9, 2022 | 07:21 AM
bluecoupe's Avatar
I'm not sure about sc pulley I think 72mm is stock anything smaller is aftermarket, there isn't a pulley saver kit so I'm guessing the crank pulley is stock. You'll need to measure to be sure, 155mm is stock, larger is aftermarket.
Old Apr 10, 2022 | 07:10 AM
Sussudio's Avatar
74mm is stock iirc. Edit: I saw you posted about the isolation kit.
Old Apr 11, 2022 | 12:12 PM
zip439's Avatar
Originally Posted by DTMenace
Nutrix
Dennis
DTMenace
Using the info in the data base provided in the quote above you may find your VIN, if so the previous owner can be found if a member of this site and you could search for his posts which may help you with the history of your car.
2fastNstuff
Sep 7, 2019 07:24 PM
dahntahn
Jul 10, 2019 04:00 AM
amx1397
Oct 2, 2018 06:21 PM
theodore.garland
Aug 18, 2018 12:25 AM
m3gene
Mar 20, 2017 08:39 AM
