Maintenance questions
Old Aug 11, 2022 | 02:40 PM
gloverSRT6's Avatar
Default Maintenance questions
I have a 05 SRT Roadster. Have owned it since 2011. It had about 21k miles when bought and now about 74k miles. It has the Needswings DCAI, 65mm pulley, upgraded fuel pump and Eurocharge reprogramming. I just finished the process of building a house and had to store the car for about 4 months while this was going on. When talking the car out of storage the battery was dead and replaced. The tire pressure light seems always coming on. My waterpump for the intercooler was starting to give me trouble so it triggered the Check Engine light. But coming out of storage the BAS/ESP light and Airbag light is on. Any ideals? Have not had the codes scanned yet. Also when slowing down sometimes I get a metal to metal clanking sound. Does not do it often, does not do it while cruising or putting it into drive or reverse. Open to all ideas. Thanks
Old Aug 11, 2022 | 03:33 PM
Default Re: Maintenance questions
How many miles have you put on it since changing the battery? I don't think the intercooler pump triggered the check engine light.
Old Aug 11, 2022 | 03:37 PM
gloverSRT6's Avatar
Most likely about 500 miles.
Old Aug 11, 2022 | 04:45 PM
Try to reset the BAS/ESP light by starting the car, turning the steering wheel as far to the right as you can then as far to the left as you can and the back to center. Turn the car off for a few minutes and restart. This usually causes the light to go out.
Old Aug 11, 2022 | 08:44 PM
RCM failed
Old Aug 12, 2022 | 01:55 PM
Originally Posted by gloverSRT6
I have a 05 SRT Roadster. Have owned it since 2011. It had about 21k miles when bought and now about 74k miles. ..... .....Have not had the codes scanned yet. Also when slowing down sometimes I get a metal to metal clanking sound. Does not do it often, does not do it while cruising or putting it into drive or reverse. Open to all ideas. Thanks
Would try to figure out that 'metal to metal clanking sound' before it gets more expensive than it may already be. CHECK the rear sway bar mounts top rear above the axle at the frame, could be the 'few times reported' broken mount(s) here in the forum. Good luck!
karenshaw
May 2, 2017 10:28 AM
SemperFi
Mar 30, 2015 04:23 PM
Lane2380
Apr 27, 2013 10:17 AM
new2crossfire04
Dec 4, 2010 05:21 PM
mecoder
Sep 2, 2006 03:59 AM
