Sensors on the front M112
Old Mar 15, 2023 | 12:16 PM
1NAR's Avatar
Question Sensors on the front M112
What are these sensors and is it possible to get rid of them without sacrificing engine performance? If I do get rid of them would I need to plug anything else up? I think these are the "EGR Changover valve" and I dont know what the right one is.
Old Mar 15, 2023 | 12:21 PM
Default Re: Sensors on the front M112
Isn't your car an SRT? If so, this belongs in the SRT area - otherwise, you are going to get some interesting responses. Many here make assumptions.
I can move this thread for you. That, or just post this in your other thread and get all your answers at the same time.
Old Mar 15, 2023 | 12:30 PM
1NAR's Avatar
These sensors are from the stock m112 3.2L Base (I have an e320) and I'm adding a supercharger to it, thats why I'm asking if I could just "delete" it I'm not sure where this belongs so I figured "all crossfires" would work? If you wanna move it feel thought ^<^
Old Mar 15, 2023 | 12:48 PM
NeedsWings's Avatar
the changeover valve on the left gets reused with the 2ndary air injection system, it does not hinder performance.
the MAP sensor on the right needs to be swapped out for a c32 MAP sensor as they are different, it gets installed on top of the intercooler.
i spy a 6 rib belt, are you planning on spinning the SC with that or converting the drive system to 8 rib?
Old Mar 15, 2023 | 12:59 PM
1NAR's Avatar
I was planning on keeping it a 6 rib, After inspecting the map sensors the stock m112 has 3 wires and a different connector then the m112k with only two wires, is it as simple as removing a wire and splicing the others together?
Old Mar 15, 2023 | 01:27 PM
NeedsWings's Avatar
wire diagrams to compare are at
https://www.crossfireforum.org/forum...ollection.html
half way down the first post
2005 Crossfire NA & SRT6 (Coupe & Roadster) Service Manual [79.7MB]
Old Mar 15, 2023 | 02:01 PM
1NAR's Avatar
GOT IT! I realized I was staring at the Air intake temp sensor >.>' Thank you for linking the wire diagrams too <3
onehundred80
Mar 23, 2019 09:27 PM
caseydeankopp
Sep 13, 2015 07:25 PM
2004_
Sep 4, 2015 01:39 PM
ardenian
Apr 28, 2015 04:33 PM
user 8202
Canada
Dec 13, 2009 12:24 AM
