fixed pulley scam
fixed pulley scam
fixed pulley its a scam, the vendors that sell them , will send you to another tuner, being tuner themselves
they send you to vtech then theyll send you 2 or 3 tunes, none will work . fixed pulley is untunable. thats why not reputable tuner works them
car will work for a few days but as the fuel trims interact with the tune, then the car will hunt and stumble badly even on idle, and the car will go super lean when open loop activates, almost blow my engine
, the ecu will see all that extra air pulled from the fixed pulley at idle, that will screw the load value and throw map sensor check engine light. car will hunt and die. no way around that.
vrp, eurocharged, ultimatepd none will tune them, theres a reason for that
someone has long term success with them?
Re: fixed pulley scam
I have had VTech now going on about at least 6 years I been on a fixed setup for about 4 years from a 181/69 clutched 181/63 clutched 181/63 fixed 181/62 fixed 181/60.5 fixed clutchless ,don't believe the hype about intake temps I have proof my car runs at or below ambient temps if the cooling mods are done properly so,if you have a fixed pulley yes contact him thru Facebook messenger I have over 100 tunes for the setups I have had my car is a happy camper thanks to VTech .Never buy those fixed pulley and tunes combo you are definitely correct I knew it was a scam .
Cheers,
Chris
I have a plm larger than stock heat exchanger,a bmw m5 heat exchanger stack with that running thru my heater core and back to my water tank I can run a 35 to 40 degree intake temps using ice or just cruising of the ambient temps is 85 or below our side my intake temps or always 10 to 12 degrees below I made several videos showing that and also I could usey ac to drop temps if needed ,also my system is separatedy big manifolds have several coats of heat resistant paint on them as well as my intercooler and supercharger so the simple overlooked stuff works .
That's a first about VTech he actually walked me thru on how to tune my vehicle out of all the tuners I had he had the best customer service but definitely sorry to hear about what happened to you you get it running post what you actually had to do for future reference
Ganny x has fixed Sc pulley along with a killer chiller and runs it every day for the last 3 or 4 years tuned by the swap shop josh can tune a fixed and non fixed srt6 ans tunes the mode TCU . very few of you know about the tunes mode TCU
start treatment next week will post and answer post until i can't jim
Sussudio (05-04-2023)
In my SLK32, I only have a larger HE and better pump and regularly have IAT temps of 15 to 25F above ambient. In my SL55, I have an FI Interchiller set up and IAT usually runs 20 to 40 F below ambient. Your set-up sounds like it is keeping temps in the sweet spot. very nice.
Chris
Thanks for the detailed reply. cool set-up.
Chris
Chris
nickwe21
05-11-2023 05:53 PM
