Calling all SRT-6 Enthusiasts
I want to increase my HP to get closer to the 400 hp mark. I would love input from anyone who has undertaken this. I want to keep it simple, and upgrade the pulley, ECU, intake and cat-back exhaust. I was looking at the Kleeman system as tried and true...all comments are welcome!
I'm in the same boat as you. The only intake I found was the one from evosport, The SLK intake mod. I still can't find an exhaust system for the car. I'm thinking of using H&R springs to lower the car 1" and upgrading my wheels to 20" out back and 19" up front. I don't know if they make sway bars for this car either.
Originally Posted by coony3737
i too have looked into this, and what i found was that by doing the ecu mod along with the pulleys will yield very close to 400 at the wheels. add intake and exhaust and i'm sure you'll be easily sitting over 400.
Originally Posted by SRT6_Roadster
Not sure why there would be an issue with dynoing the car. You just have to go to a competent shop.
The SLK32's are putting down 290-300 hp on a Dynojet.
Originally Posted by respdoc
Search my past posts for some recommended mods...
Sohc,
The intake is from the SL55... (also wrote about in my past posts if your interested)...
Sohc,
I'm also looking at pulleys. The evosport slk32 amg kompressor (odps) looks good but I don't see the supercharger pulley in the kit so I don't know if it'll work. Right now I'm kind of
. If you or others could point me in the right direction. I kind of don't want to STF...
Originally Posted by sohc808
Well after reading multiple posts on the exhaust system. I finally took my car to a local exhaust shop. The owner and myself were under the car looking at the system and decided to take out the resonator. Took them a while, but to me it was worth it... The exhaust note just sounds so much better.. I will be reading more of your past posts... Btw.
. If you or others could point me in the right direction. I kind of don't want to STF...The removal of the supercharger pulley can be tricky esp. if your looking at doing a DIY project and with the stock supercharger pulley being relatively small to begin with...the net gains might not be worth the effort...
My quick and easy suggestion is to install the SL55 full intake and if you live near CO have Kleemann install their pulley and ECU flash and that should get you near the 400 h.p. neighborhood.....
I'm asking you because you seem to know alot about this car. I will continue to search your posts. Btw thanks for the replies...Mahalo...
. If you or others could point me in the right direction. I kind of don't want to STF...Thread
