Bad headlight lense
Old Oct 2, 2007 | 01:47 PM
sparks81's Avatar
Default Bad headlight lense
Any idea how to fix this without replacing the whole assembly?
At first I thought it was from over buffing the hood onto the lense. Then I thought it was from condensation inside the lense. Now I'm not sure.
Old Oct 2, 2007 | 01:51 PM
RPM's Avatar
RPM
Moderator
Default Re: Bad headlight lense
Looks to me like there has been moisture on the inside. I think there is a TSB on the headlights on there somewhere.
You can try some Meguiar's Plastx plastic polish/cleaner if you think it is on the outside.
Old Oct 2, 2007 | 02:04 PM
DanielNTX's Avatar
This is what happened to mine. You need 1,500 grit and 3,000 grit sandpaper. See this thread: https://www.crossfireforum.org/forum...5&postcount=13
Oh yeah it's like $458 to replace a single assembly, plus labor.
Old Oct 2, 2007 | 03:44 PM
Iamfink2's Avatar
Same thing happened to mine but was replaced under warranty. So far no problems.
Old Oct 2, 2007 | 04:57 PM
BrianBrave's Avatar
<--- Huge Horsepower
Mine was even worse on one and just a spot on the other - Dealer wrote it up as delamination and I got two new complete assemblies, installed, zero cost, plus a free Chrysler 300 rental for the day.
Old Oct 2, 2007 | 06:48 PM
Brent's Avatar
Same problem with mine and they were replaced under warranty.
Old Oct 3, 2007 | 02:33 PM
herfire's Avatar
If the headlight lens is just cloudy from the sun. I have used 303 Aerospace Protectant which is available at marine supply stores, unless you have a really good auto parts store. Use a cotton cloth and put some on the cloth and rub it like you were polishing metal use some force let dry and buff off with another clean cloth repeat and it should take care of about 90%. Lasts for a couple washings or rain showers. Also great on tires if you do not want a shine. Rubber molding etc. Has a good UV inhibitor in it, great stuff. Better than sanding or buffing.
Old Oct 7, 2007 | 11:29 AM
patpur's Avatar
Senior Member/Moderator
Its my understanding that some of the headlight assemblies that have been replaced are doing this after time. I had the same issue with my original headlights and used 3M Plastic Cleaner the first time. I will tell you what works and takes about 10 minutes. Mequiars ScratchX and a Porter Cable. It polishes right off. I am blown away with the Porter Cable, great investment.
Pat
Old Oct 7, 2007 | 08:02 PM
Sally Schrauder's Avatar
Smile Re: Bad headlight lense
Hi, This is Sally... I just want to thank everyone for their input. I'm having the same problem with my headlight lense. I will try taking it back to the Dealer, and if that doesn't work. I will try the mequiars plastx plastic /cleaner. I'm scared to use the 1,500-3,000 grit sand paper.
Thanks,
Sally
Old Oct 8, 2007 | 04:03 PM
patpur's Avatar
The sandpaper scares me too. If you can find someone with a Porter Cable or other buffer you are looking at a 10 minute fix. 3M also makes a plastic scratch remover that you can get on their website for about $8 bucks.
Pat
Old Apr 26, 2008 | 09:35 PM
FTroopChief's Avatar
Caused by UV and outside unprotecetd parking. I've used MacAleer's, 3M 39010 and the best I've found is JANVIL, used in conjuction with 1500-3000 GRIT WET or DRY used wet. Depending on damage to lens, 3 part JANVIL alone may work. The secret is in the strokes. One direction horizontal L>R. Reverse direction when changing grit or polish. www.janvil.com
1-877 4 JANVIL. About $21.00 for 3 8 oz bottles kit, + S&H
FTroopChief (former Pressure Suit Mechanic)
Old Apr 26, 2008 | 10:00 PM
Rokypoky's Avatar
I was told by someone that there was a kit at auto zone that you can use it comes with a buffing pad that goes n a drill supposed to very well. a Mech. at a dealer was the one telling this
Old Apr 26, 2008 | 10:52 PM
CrossfireLTD's Avatar
Cool Re: Bad headlight lense
I have used this kit in the past and it works well. If this is condensation on the inside of the lens, then you should take it back to the dealer and it will be replaced under warranty (assuming the car is still under warranty).
Old Apr 27, 2008 | 05:53 AM
maxcichon's Avatar
Lightbulb Re: Bad headlight lense
I've used (on both my kid's cars) a product/kit called Crystal View:
http://www.crystalviewchemicals.com/
with very good results. Wal Mart $20.
Alternatively, there is a thread on the forum showing a BMW getting an excellent re-do of it's headlights too. It may be scary, but it works very well.
Old Apr 27, 2008 | 08:33 AM
bigbengt67's Avatar
Does anybody have a link to this TSB? I want to use it to get my dealer to fix mine before the warranty is up.
Old Apr 27, 2008 | 11:21 AM
Here ya go:
TBS: 13-Jan-05 - 08-002-05 - Lighting - Condensation in Headlamps
Old Apr 27, 2008 | 02:55 PM
bigbengt67's Avatar
Thanks alot!
Old Apr 27, 2008 | 03:56 PM
Stogey's Avatar
Check out my gallery ! I too used the Crystal View product. I posted before, during processes 1 and 2 and afterwards. The stuff works as advertised except for the five minute per lense part !!!
20 bucks at your local Wally World
Just my Dos Centavos !
Old Apr 27, 2008 | 06:37 PM
RMADERMAN's Avatar
The sand paper also scared me. I bought some 1500 and 2000 grit wet/dry sandpaper ($10), a varible speed polisher ($150) and some 3M liquid polishing compound ($25). That probably cost me around $200. Yes, it worked perfectly. I used it on mine and Ahley's headlights. If I were you I would buy the stuff at walmart if you do not feel comfortable with the sanding.
For me it was a different situation because I wanted to use the polisher on the entire car. All three cars if I must include the wifes Town and Country. The cleaning of the SRT's is my therapy. Much cheaper then a shrink I think.
If the dealer does not help you, I am sure they have someone or if it is like my dealer there is an advertisement where I drop the car off showing the before and after pictures of fogged headlights, Good luck.
Old Apr 28, 2008 | 10:05 AM
Stogey's Avatar
Actually the kit from Wally World comes with two different grits of sanding material with the cleaning solution impregnanted into the paper. Be sure to read the instructions before you begin !
The trick, I found is to keep the lense really wet while going thru the sanding process. A spray applicator bottle using tap water works really well for this. Once the sanding process is completed then you wipe on the sealer and you're done. I taped the painted area around the lense with painters tape just because.
I don't usually hawk a product like this, but the stuff works and it's a whole heck of alot cheaper than replacing the lense.
