Sanding Plastic?
Old Jan 29, 2008 | 06:55 PM
Utah12's Avatar
Default Sanding Plastic?
I have a positive battery cover that I want to paint black and use as a negative. What is the best way to get rid of the raised positive sign? Sanding? Scraping? Also what is the best paint product to use to get a flat satin black finish?
Old Jan 29, 2008 | 07:47 PM
Mike-in-Orange's Avatar
Default Re: Sanding Plastic?
You should be able to take the bulk of it off with a razor utility knife and then sand the rest smooth. Since it's plastic you should be able to pick up any color paint you like from a hobby shop and paint away!
Old Jan 29, 2008 | 07:59 PM
DrMike's Avatar
Use wet sandpaper and water with x-fine grit, that way you micro scuffed, paint will adhere better and sand marks will not show. Make certain to clean surface before painting
Dupli Colour paint, Wal-Mart about $6.00 a can
Old Jan 29, 2008 | 09:10 PM
newCrossfire's Avatar
razor blade is probably the best idea for removing the positive sign. but you have to be extra careful sanding plastic!!! if you use anything coarser then 600 grit youll need to prime the part and then sand it again with 600 or higher wet paper. what happens is when you sand on the plastic it actually kind of creates these little furrs and when you paint over them it just looks really rough. so to get rid of those furrs youd have to use a primer filler over the sanded plastic and then when you sand the primer down it will smooth out all the roughness and furrs. the easiest way would to just be as exact as possible cutting off the sign with a razor blade and then just scuff the rest of the piece with some GREY scotch bright.
Old Jan 30, 2008 | 02:18 AM
GDC-SRT's Avatar
Krylon makes paint special for plastic. It really bonds well
Old Jan 30, 2008 | 08:12 AM
HJM's Avatar
HJM
Please verify that the cover is not made from Polyolefines (PE and PP) No paint will work on those materials without extensive preparation like Plasmatreatment.
I would spend the funds on buying a black version!
By the way - I am plastic processing engeneer and was involved in the development of the body parts for the BMW Z1!
HJM
Old Jan 30, 2008 | 02:30 PM
jonnyangel04's Avatar
wow HJM impressive glade to have you onboard
smfrycruzr
Jul 17, 2023 05:33 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
tritongreen
Sep 18, 2015 07:32 AM
jaesa
Sep 7, 2015 01:50 PM
